What surrounds for my SDA SRS's??
jcmccorm
jcmccorm Posts: 103
edited September 2009 in Vintage Speakers
Hey folks, question...
I'm building a theater (finally) and plan to use my SDA SRS's for the mains in a 7.1 setup. The SDAs have the tweeter upgrades (194's?) and the crossovers have been upgraded. They are in good shape and ready to go.
In my old theater (as in pre-divorce, different house) I used SDA 1C's for surrounds. Not a bad deal. This go-around I'll be building a "proper" theater (ie need WAF) and need in-walls for the backs and real surrounds for the sides that will fit into some columns I'll build.
What do you guys with the SDAs use for surrounds? I was thinking about the LSiFX's for sides and in-wall LC265's for rears. Any other Polk products that would work well? Anything else I should consider?
Thanks!
Cary
    nooshinjohn Posts: 26,184
    I run LSi-15's and am quite pleased with them
  • jcmccorm
    jcmccorm Posts: 103
    Thanks!
    Running a floor-stander for surrounds would be nice (did it with the 1C's) but I don't think I could hide those things in a column! It's nice to know that the LSi series works well with the SDA's though (assuming that the LSiFX is well matched to the LSi15's).
    Cary
