Powering SDA-iC
vijayl
vijayl Posts: 258
edited October 2009 in Vintage Speakers
Hav a chance to score ONK A-9555 under $300 looks pretty new. Is it any good for driving SDA-iC? I'll either use Pio VSX52 or VSX-33TX as pre.
A-9555 rated 130 wpc @ 8ohms and 200 wpc @ 4ohms. My guess SDAs may get 160wpc.
Is A-9555 anygood at $300?
Can this amp be bi-amped?
Is it wise to drive it with this at this time and may be bi-amp
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
, logitech 880
Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50
Post edited by vijayl on
  • cayovelez
    cayovelez Posts: 77
    edited September 2009
    I was under powering them with an Adcom GFA-545ii, they still sounded great but not deep enough. I was lucky to get a conrad johnson 200 watts per channel amp, and my speakers came alive. So very happy with my 1c. From what I have read on other post they need power, clean power. I am thinking on jumping the tube way, but...
  • Ron Temple
    Ron Temple Posts: 3,212
    It really depends on the current capability of the amp. I was really surprised on how an Audiosouce Amp300 sounded on my 1Cs, 150/8, 280/4. It pushed mine pretty hard with plenty of bass. It wasn't as defined as my Carver, but my friend only paid $120.00 for it.
    All amps aren't equal no matter the power rating, but rule of thumb, if you want to keep your budget around $300, then look for an Adcom GFA 555 (II) or Carver TFM 35...I know they will work spendidly with 1Cs and they aren't too hard to find.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vijayl
    vijayl Posts: 258
    , logitech 880
    nooshinjohn Posts: 25,927
    vijayl wrote: »
    if you can talk him down to 400.00 I would snap that up as it is an excellent fit with the 1c's. I ran a TFM-35 with mine and the sound was excellent. :)
  • Ron Temple
    That's pretty much an average price for a TFM 45. $400 is a very good price. Is the 55x still on CL? He wanted $450 and might have taken $400.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vijayl
    vijayl Posts: 258
    Ron, I think u meant GFA-5500? Its still available.. I'll try for TFM-45 and if I don't get it, I may try GFA-5500
    , logitech 880
  • Ron Temple
    vijayl wrote: »
    No there was a 55x on CL in the Livermore/Pleasanton area for quite awhile. It was there the last time I looked. The GFA 5500 is not common ground. You'll need to check about binding the negative terminals with Adcom or have Ben make you a cable.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vijayl
    vijayl Posts: 258
    whew.. Thx Ron.. I'm going this eve to pickup the TFM 45. Lets see if I get it..
    , logitech 880
  • vijayl
    vijayl Posts: 258
    Just picked up the TFM-45 this morning. I'll go home and give a listen later at night.. I got it for a good price..
    I have a Question: the lights are not working on the amp. Can u please let me know where can I get the lamp and is there any special things that I need to be careful abt for replacing the lamps/bulb?
    Thanks everyone for the suggestions and it was very helpful for me..
    , logitech 880
  • Ron Temple
    Check the Carver site. There's usually someone who either has the lamps or instructions on replacement. There's usually a guy on ebay that sells the bulbs too. I hope you demoed the amp while there. The bulbs do burn out, but I hope it's not an indication of further problems.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vijayl
    vijayl Posts: 258
    , logitech 880
  • vijayl
    vijayl Posts: 258
    Thanks Ron for the refl. I ordered the lamps already..
    , logitech 880
  • vijayl
    vijayl Posts: 258
    TFM 45 goes very well with SDA 1C. I don't hav a pre yet, but running off of iPod. So far so good. Any thots on using this AVR Pio Eli VSX-24TX as pre?
    , logitech 880
    congrats on the amp. The lamps are easily replaced. I use an AVR for my pre and although it gets the job done, I am looking for something better. I would love to find a tube-pre that has HT bypass. For now I am sure it will get the job done.
  • vijayl
    vijayl Posts: 258
    Thanks John.. Whats ur opinion abt this? McIntosh
    , logitech 880
  • Ron Temple
    vijayl wrote: »
    Looks good, though if you want to run a sub, I'm unclear from the specs if there's a sub pre-out...just mentions L/C/R/S 5.0. If there is a sub pre-out somewhere, then it looks like a fine HT pre to start with on a budget.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vijayl
    vijayl Posts: 258
    It does hav a pre-out for a Sub
    , logitech 880
    vijayl wrote: »
    I have no direct experience with the Mac's but I do desire to try them someday:). I like the way this one looks on paper, but am not certain if the pricing is fair or about the way it will work with the Carver.
  • polksda
    polksda Posts: 716
    I'm powering SDA 1Cs (possibly soon to be replaced, but more on that later) in my HT with a Carver M-4.0t (Denon AVR-2807 with preouts to the Carver). Does a fabulous job.
  • gdb
    gdb Posts: 6,012
    Howdy polksda ! I just wanted to say that your website is very helpful and informative ! Thanks !!:D
  • vijayl
    vijayl Posts: 258
    edited October 2009
    Gotta Carver Pre CT-17 and CDP TL-3200. They sound awesome w/ TFM-45.. I have to hook up the 1Cs sometime this week
    , logitech 880
