Powering SDA-iC
vijayl
Hav a chance to score ONK A-9555 under $300 looks pretty new. Is it any good for driving SDA-iC? I'll either use Pio VSX52 or VSX-33TX as pre.
A-9555 rated 130 wpc @ 8ohms and 200 wpc @ 4ohms. My guess SDAs may get 160wpc.
Is A-9555 anygood at $300?
Can this amp be bi-amped?
Is it wise to drive it with this at this time and may be bi-amp
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50
Post edited by vijayl on
I was under powering them with an Adcom GFA-545ii, they still sounded great but not deep enough. I was lucky to get a conrad johnson 200 watts per channel amp, and my speakers came alive. So very happy with my 1c. From what I have read on other post they need power, clean power. I am thinking on jumping the tube way, but...
It really depends on the current capability of the amp. I was really surprised on how an Audiosouce Amp300 sounded on my 1Cs, 150/8, 280/4. It pushed mine pretty hard with plenty of bass. It wasn't as defined as my Carver, but my friend only paid $120.00 for it.
All amps aren't equal no matter the power rating, but rule of thumb, if you want to keep your budget around $300, then look for an Adcom GFA 555 (II) or Carver TFM 35...I know they will work spendidly with 1Cs and they aren't too hard to find.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
whats an ideal price for http://sfbay.craigslist.org/sfc/ele/1374576983.html
Def Tech Mythos ST
Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
Storage-RTi8,CSi5,PSW505,Monitor50 -
if you can talk him down to 400.00 I would snap that up as it is an excellent fit with the 1c's. I ran a TFM-35 with mine and the sound was excellent.whats an ideal price for http://sfbay.craigslist.org/sfc/ele/1374576983.html
That's pretty much an average price for a TFM 45. $400 is a very good price. Is the 55x still on CL? He wanted $450 and might have taken $400.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron, I think u meant GFA-5500? Its still available.. I'll try for TFM-45 and if I don't get it, I may try GFA-5500
Def Tech Mythos ST
No there was a 55x on CL in the Livermore/Pleasanton area for quite awhile. It was there the last time I looked. The GFA 5500 is not common ground. You'll need to check about binding the negative terminals with Adcom or have Ben make you a cable.Ron, I think u meant GFA-5500? Its still available.. I'll try for TFM-45 and if I don't get it, I may try GFA-5500
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
whew.. Thx Ron.. I'm going this eve to pickup the TFM 45. Lets see if I get it..
Def Tech Mythos ST
Just picked up the TFM-45 this morning. I'll go home and give a listen later at night.. I got it for a good price..
I have a Question: the lights are not working on the amp. Can u please let me know where can I get the lamp and is there any special things that I need to be careful abt for replacing the lamps/bulb?
Thanks everyone for the suggestions and it was very helpful for me..
Def Tech Mythos ST
Check the Carver site. There's usually someone who either has the lamps or instructions on replacement. There's usually a guy on ebay that sells the bulbs too. I hope you demoed the amp while there. The bulbs do burn out, but I hope it's not an indication of further problems.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Interesting Post on Carver Site: http://thecarversite.com/yetanotherforum/default.aspx?g=posts&t=193
Def Tech Mythos ST
Thanks Ron for the refl. I ordered the lamps already..
Def Tech Mythos ST
TFM 45 goes very well with SDA 1C. I don't hav a pre yet, but running off of iPod. So far so good. Any thots on using this AVR Pio Eli VSX-24TX as pre?
Def Tech Mythos ST
congrats on the amp. The lamps are easily replaced. I use an AVR for my pre and although it gets the job done, I am looking for something better. I would love to find a tube-pre that has HT bypass. For now I am sure it will get the job done.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thanks John.. Whats ur opinion abt this? McIntosh
Def Tech Mythos ST
Looks good, though if you want to run a sub, I'm unclear from the specs if there's a sub pre-out...just mentions L/C/R/S 5.0. If there is a sub pre-out somewhere, then it looks like a fine HT pre to start with on a budget.TFM 45 goes very well with SDA 1C. I don't hav a pre yet, but running off of iPod. So far so good. Any thots on using this AVR Pio Eli VSX-24TX as pre?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
It does hav a pre-out for a Sub
Def Tech Mythos ST
I have no direct experience with the Mac's but I do desire to try them someday:). I like the way this one looks on paper, but am not certain if the pricing is fair or about the way it will work with the Carver.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I'm powering SDA 1Cs (possibly soon to be replaced, but more on that later) in my HT with a Carver M-4.0t (Denon AVR-2807 with preouts to the Carver). Does a fabulous job.
Howdy polksda ! I just wanted to say that your website is very helpful and informative ! Thanks !!:D
Gotta Carver Pre CT-17 and CDP TL-3200. They sound awesome w/ TFM-45.. I have to hook up the 1Cs sometime this week
Def Tech Mythos ST
