Computer Help
audiobliss
audiobliss Posts: 12,518
edited September 2009 in The Clubhouse
I have a file on my computer that got messed up in downloading. It says it's 0 bytes, and it won't let me delete it or rename it, because "cannot be read from the source file or disk."
How can I get rid of this?
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Sometimes booting into safe mode helps, in deleting a file.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • audiobliss
    Thanks. I'll try that sometime tonight or tomorrow.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,734
  • audiobliss
    jerk
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • SWFalken
    SWFalken Posts: 136
    I'm not sure anymore but I used to boot into dos and remove the offending files manually. I have not had to do that in a very long time and I'm not even sure you can do things like that with newer versions of Windows.
    "I drank what?" Socrates :eek:
  • Sherardp
    Sherardp Posts: 8,038
    + 1 for rebooting into safe mode
  • audiobliss
    Ok, STUPID question. But I remember I had to ask this last time I wanted to boot into safe mode. HOW do I boot into safe mode? On the boot screen I didn't see any of the F-keys being bound to booting into safe mode.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    Lasareath wrote: »
    Every 0.25 seconds hit the F8 button while the computer is booting. that will give you the menu to choose safe mode
    That error usually means that there is a bad sector on your hard disc and that's why it can't be removed.
    I would do a defrag and a scandisk first, then try to remove it.
    Ok, am defragging now.
    Thanks for the advice!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    Ok, problem. I defragged, still got the same error.
    Then I booted into safe mode, and I still got the same error.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Airplay355
    Airplay355 Posts: 4,298
    Put your right hand in the air while you click your heels together and hold down all the F keys. Then use your tongue to restart the computer, that should work.
  • audiobliss
    Airplay355 wrote: »
    Can you come help me? I'm holding my right hand in the air...I'm pretty sure I'm holding it high enough...but I can't mash down all these F-keys with just my left hand.
    Oh, and is the regular 'F' key between 'D' and 'G' included in 'hold down all the F keys'?
    Thanks!!!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • AudioGenics
    AudioGenics Posts: 2,567
    just a suggestion but check this url for tips...
    curious to know what OS you are using.
    Cannot delete file Cannot read from the source file or disk
    You cannot delete a file or a folder on an NTFS file system volume
    http://support.microsoft.com/kb/320081
    See: Invalid File Names here...
    How to locate and correct disk space problems on NTFS volumes in Windows XP
    http://support.microsoft.com/kb/315688
    How to Remove Files with Reserved Names in Windows
    http://support.microsoft.com/kb/120716
    How to Remove Files with Reserved Names in Windows XP
    http://support.microsoft.com/kb/315226
  • fatchowmein
    fatchowmein Posts: 2,637
    I'm assuming you're on Xp or Vista.
    Try running chkdsk /r from a command prompt. If the file is on your system partition (C drive), it'll ask you to reboot and check disk will run when it boots up. Hopefully, this will fix it by removing the offending file or unlocking it so you can delete it. If the file is not on your C partition, you'll get a warning that the partition is locked and in use and it'll ask if you want to unlock it for check disk to use. Type 'Y' or "yes' (I forget which) and let it do its thing.
    Good luck and keep a close eye on your drive. It may be dieing and you may wish to start back stuff up.
  • Use LongPathTool, Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename.
  • Willow
    Willow Posts: 11,250
    I'm going out on a limb...but I think they have solved it in the past 10 years. But thanks for your input
