Computer Help
audiobliss
I have a file on my computer that got messed up in downloading. It says it's 0 bytes, and it won't let me delete it or rename it, because "cannot be read from the source file or disk."
How can I get rid of this?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
Sometimes booting into safe mode helps, in deleting a file.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Thanks. I'll try that sometime tonight or tomorrow.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
jerkGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I'm not sure anymore but I used to boot into dos and remove the offending files manually. I have not had to do that in a very long time and I'm not even sure you can do things like that with newer versions of Windows."I drank what?" Socrates :eek:
+ 1 for rebooting into safe modeShoot the jumper.....................BALLIN.............!!!!!
Ok, STUPID question. But I remember I had to ask this last time I wanted to boot into safe mode. HOW do I boot into safe mode? On the boot screen I didn't see any of the F-keys being bound to booting into safe mode.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Every 0.25 seconds hit the F8 button while the computer is booting. that will give you the menu to choose safe mode
That error usually means that there is a bad sector on your hard disc and that's why it can't be removed.
I would do a defrag and a scandisk first, then try to remove it.
Thanks for the advice!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Ok, problem. I defragged, still got the same error.
Then I booted into safe mode, and I still got the same error.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Put your right hand in the air while you click your heels together and hold down all the F keys. Then use your tongue to restart the computer, that should work.
Airplay355 wrote: »Put your right hand in the air while you click your heels together and hold down all the F keys. Then use your tongue to restart the computer, that should work.
Oh, and is the regular 'F' key between 'D' and 'G' included in 'hold down all the F keys'?
Thanks!!!!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
just a suggestion but check this url for tips...
curious to know what OS you are using.
Cannot delete file Cannot read from the source file or disk
You cannot delete a file or a folder on an NTFS file system volume
http://support.microsoft.com/kb/320081
See: Invalid File Names here...
How to locate and correct disk space problems on NTFS volumes in Windows XP
http://support.microsoft.com/kb/315688
How to Remove Files with Reserved Names in Windows
http://support.microsoft.com/kb/120716
How to Remove Files with Reserved Names in Windows XP
http://support.microsoft.com/kb/315226 -
I'm assuming you're on Xp or Vista.
Try running chkdsk /r from a command prompt. If the file is on your system partition (C drive), it'll ask you to reboot and check disk will run when it boots up. Hopefully, this will fix it by removing the offending file or unlocking it so you can delete it. If the file is not on your C partition, you'll get a warning that the partition is locked and in use and it'll ask if you want to unlock it for check disk to use. Type 'Y' or "yes' (I forget which) and let it do its thing.
Good luck and keep a close eye on your drive. It may be dieing and you may wish to start back stuff up. -
Use LongPathTool, Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename.
I'm going out on a limb...but I think they have solved it in the past 10 years. But thanks for your input
