Summing transformers
ben62670
Well I have a bunch of 2 amp 28.7v center tapped transformers. I need to sum the amperage of them. Can this be done with satisfactory results? Would I rectify the ac, and sum them all? Also what if I ran the secondaries as primaries?
Would this be a way to boost the voltage to run some tube projects? If my math is correct I could get a B+ of 240vdc if I bypass the center tap?
Ben
Ben
Ben
Ben
Post edited by ben62670 on
Without thinking it through, I'm saying yes.
Do not run the secondaries as primaries, they will likely burn out. -
I think all the wires are rated a 600v. I know nothing real bad would happen summing DC, but I have never done it, and noise is the only thing I am concerned about.
Ben -
As DC, you simply sum them via a diode on the output of each supply before the summing junction. This is what is done with "redundant" power supplies.
In that case, it's not done to take advantage of the current, just to keep DC available if any supply dies. The diode isolates each supply from the others. Make sure the diode can more than handle the current you're supplying.
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
Being you have a 4.28 to 1 ratio transformer, I think if you power the secondary you should have 514vac output. :eek:
Your center tapped transformer for 28vac you could use the outside wires and not use use the center wire. You then have a 28vac transformer, using the center wire so you diode the output wires together with the center being the return wire. You have 14vac transformer with double amp out.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I like the sound of 514v. I could tube rectify and tube regulate. I was surprised with the SQ of a tube pre with that setup.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Hmmm.....
I don't like the fact you may power up the secondary coil, you may need to try that first. Check for smoke. 514vac should be around 600vdc when you diode up and put a cap on it.
Your nuts, but I think you know that already.
BTW I may be able to get an used high voltage transformer, I could pick one up and you could pay me later when I go up there to see those speakers. I just need to know what the transformer watts you need and the voltage in and out you need. And the most $ you what to pay for it.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Yeah I ain't scared. The doctors are still trying to figure out if I'm nuts or stupid.
I was going to try one outside with an extension cord, a light fuse, and on the driveway. If it sizzles oh well. If not I'll put a load on it, and see what happens. I am just looking for something to play with. I can't sink any money into a transformer yet, but I can work on the design if I know what I have to play with. Thanks much for the offer, but I have to pass for now. See ya soon:)
Take care.
Ben -
I could still check to see what's available, it's old military stock sometimes things are really cheap. I'm thinking $20 - $30 bucks with "Free delivery" you pay what the receipt is.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Can't beat that. I'll give you a call soon(in a few days) when I figure out what I need. I have your number plugged in, but I don't remember the best time to call.
Thanks Steve.
Ben -
Ben, anytime during the day is cool to call.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
