Anyone here with an IB subwoofer set up?
Ron-P
Ron-P Posts: 8,520
edited September 2009 in DIY, Mods & Tweaks
Now that I rearranged my theater room and got rid of the futon I have no space for a big box sub. Currently I've been using a 15" Tempest ported with duel 17" ports and a 250w plate amp in a custom built box. I now don't want a box in the room.
My theater is a room in the garage and I was thinking of mounting the Tempest to the wall of the theater and having it stickout of the theater wall into the garage, an IB set up I suppose.
Any tips, suggestions or otherwise would be extremely helpful. My theater is 9' x 16' x 7'.
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • ShinAce
    ShinAce Posts: 1,194
    You could always strap some felt or thick cloth around the back of the magnet to the wall. Kind of like closing the sub into a very small, very porous enclosure. It's a quasi IB. Half sealed, half infinite.
  • Systems
    Systems Posts: 14,872
    Running a driver IB will mean that there will be less of an air spring(compliance) to supply a restoring force to the drivers suspension,therefor I'm thinking you may well run into excursion problems with a single driver even though its a very good one.
    I think an IB done correctly have huge performance potential.I wish I could build one but it's not practical for my room or my marriage.
    Testing
    Testing
    Testing
  • hoosier21
    hoosier21 Posts: 4,418
    not sure OB is the way to go with a single driver.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Face
    Face Posts: 14,340
  • Ron-P
    Ron-P Posts: 8,520
    Face wrote: »
    Thanks Face. It's looking that an IB might not be for me. I think I'll just build another box for my Tempest, might be the easier (and cheaper) way to go.
    If...
  • kcoc321
    kcoc321 Posts: 1,788
    wow great link Face, thanks
  • unc2701
    unc2701 Posts: 3,587
    GV#27 wrote: »
    Yeah, you need to make sure that you have the right driver for it and preferably 2-4 of them. Check out:
    http://www.aespeakers.com/
    They've got an IB model that's pretty affordable.
    Backburner:Krell KAV-300i
