Vifa RB2 kit meets mini transmission line
2
  • ShinAce
    ShinAce Posts: 1,194
    edited September 2009
    Can we get a pic of the back of the assembled box? Or am I just being greedy?
  • ben62670
    ben62670 Posts: 15,969
    GV#27 wrote: »
    ... As for the PR they are great for subwoofers and bigger systems but we are talking about a 5" woofer in a mini monitor form factor and a first time build so IMO not practical.If bass extension is the priority then just build the ported option.Adjusting port lengths will give you the same tunability as a PR but you will have the very desirable benifit of being able to predict the resulting response with free software like WinISD
    Hey Ben long time no talky how are things?Is that Burr Brown DAC I sent you still singing sweetly?
    Hey Fred. I have been out of touch lately. The last 2 months have been pretty messed up. I am almost caught up, but I am headed back to CT for another week. This time with my girls. The DAC is doing great. There is an occasional pop even with the signal locked, but the sound is better than my GDA-700. Jerry picked up that cheap DAC you recommended. We haven't ditched the wall wart yet. I my be picking one up myself. I want to do an integrate amp with the DAC built in for the bed room. Also I am thinking about some in the wall SDA's. The only component you will see is just the Integrated amp:) The transport will be my media server via RF remote.
    As for the passive comments
    Sorry guys about the confusion/high jack. The comments were just general comments about PRs and were not directed twords this project here:o
    I was chatting with Fred in CA about doing some boards. I need to get in touch with him again too. We'll talk in a few weeks about that(I'll have a board for you to stuff). It is another piece in the puzzle on that multi tasking pre I have been working on and off for over a year. These tube head Polkies have really taught me a lot as of late. The biggest thing I have learned about tubes is the incredable sound stage that good tubes can pull off that I have never seen via SS or in passive pre's.
    Take care.
    Ben
    Ben
  • Systems
    Systems Posts: 14,872
    (Sorry this is a Reply to post #30,didnt see the second page.)
    Sure if you are trying to achieve one of the alignments like B4,QB3 etc. then you are stuck with a specific box volume and port tuning for that alignment.However with modeling software you are not held fast to a specific alignment and can by trial and error within the software find a usable non standard box volume and tuning that can give satisfactory results.
    As you are suggesting though box size/tuning relationship is very important and I have heard a few ported designs that exhibited reasonably tight and tuneful sounding bass though my preference is with sealed especially as you approach the 40hz and below range.
    Testing
    Testing
    Testing
  • Systems
    bikerboy wrote: »
    I would greatly appreciate a diagram so I can get the TL cabinet built correctly.
    It may take a few days to get the drawing done but certainly will provide you one.
    Do you use contact cement to stick the veneer to the box? I read some use elmers glue and iron it together. This will be the first veneer work I have done so it will be fun. Thanks, BB
    I use the wood glue iron on method as its much more forgiving than contact cement.I apply the glue to the back of the veneer and the box using a smalll paint roller.I recommend using paperbacked veneer to help avoid it from slitting.Also having a router with a veneer trimming bit will be a big plus.I think I posted pic's previously of thre procees,I will try to find them.
    Testing
    Testing
    Testing
  • Systems
    ShinAce wrote: »
    No pic but the line opening is at the very top of the rear and measures 4.5" wide by 1.5" high.Basically the back panel will be cut short to leave the opening at the top.The final panels are not finished or installed yet,I'm just using a removable panel for the time being.
    btw I'm looking for a source of decent and affordable(not Cardas,WBT:D) binding posts that are long enough to mount through a 3/4" panel.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
  • Systems
    ben62670 wrote: »
    Same here don't read or post much anymore,excepting the last 2 days.
    Mine was doing that aswell if I get it operational again(I stole the analog PS) I will try to find a remedy.
    Oh yeah I forgot about him getting that one,how's the build and sound quality as is?
    Oh oh,you have been brainwashed and seduced by those deceptive euphonic tube colorations.:eek::p
    Testing
    Testing
    Testing
  • ben62670
    http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=091-1245&scqty=4
    I have these. Very cheap yet solid. The solder tab makes it a breeze to solder, and remove. I have used similar ones to the ones face has posted, but you can't remove the wire without unsoldering them.
    Oh yeah I forgot about that one,how's the build and sound quality as is?
    I haven't spent any time with it, but the SQ is very good. I trust Jerry's ears. We both have very similar taste, and both agree on subtile differences. My car has been dead for almost a month. I am rebuilding the whole top end. The heads will be done tommrrow(decked, and valves recut). So I will be able to get my ears on again.
    Those dirty rats! Seriously until late all the tube gear I have heard was either washed out sounding, or more brittle than those crappy Adcom's I love so much. Before tubes were good with only certain types of music. I never thought in my wildest dreams that tubes could handle anything thrown at them. Imade a thread a while back that tubes were like bandaids. A bunch of people got their panties in a bunch without even reading what I wrote. I have a bunch of CD's that I used to love before I started getting into some real decent gear. On the newer gear the system magnified the faults. Then I had some hands on with some real nice tube pre's and amps. Those bandaid tubes really healed up some really crappy compressed sounding recordings, and still brought out excellent dynamics. Symbols just have such a live sound to them. Sound stage is so much better. I wish you were closer. Anytime you are in the area I will pick you up. What ever it takes. If I had the money I would fly you down here. I don't have gear of that caliber yet, but I have some real good friends nearby that do.
    Take care.
    Ben
    Ben
  • Systems
  • Systems
  • Systems
    edited November 2009
    I'm posting this to show BB a detailed pic of the real DB1's inards vs my clone shown in post #2 http://www.positive-feedback.com/Issue45/rmaf2009.htm. scroll down to pic# 9.It clearly shows the foam lining and partition locations.
    Testing
    Testing
    Testing
  • Systems
    Here are 3 more pics of the finished clone with laquer applied,and showing xover and foam placement.
    Testing
    Testing
    Testing
  • ben62670
    Very nice as usual. Hows the sound? You run them active yet, or just passive?
    Ben
  • Systems
    ben62670 wrote: »
    Thanks .Yes I have tried them active and not surprisingly I prefered them that way,abit more dynamic and bigger sounding partly due to more baffle step compensation being added.The steeper slope and lower xover point of the active also improves the midband smoothness.Either way they image like crazy because of the narrow baffle width.The tweeter is a sweety ,it never turns hard or brittle sounding be it with the active or passive network,surprising considering it's cost.
    Testing
    Testing
    Testing
  • ben62670
    I'm looking to do a small set of speakers for the bedroom. Something I can drive with a gainclone. I was thinking about doing a full range Fostex driver and a small tube amp, but I just can't bring myself to do it. Imaging is key, and super low bass or very high levels aren't. Again nice work.
    Ben
  • Face
    Face Posts: 14,340
    Nice job Fred!
  • Systems
    Thanks Mike.
    Ben,you might look at one of Zaph's designs with his new 5" driver.The Vifa RB2 kits are no longer available though you might be able to piece it together separatley,Madisound sells the tweet and I've seen the woofer on ebay.
    Testing
    Testing
    Testing
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Two thumbs up for your finalized project GV :cool:
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • proirklad
    proirklad Posts: 2
    A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a **** by the clean end.
  • Systems
    proirklad wrote: »
    Really,thats deep.:D
    Oh and Thanks TK.
    Testing
    Testing
    Testing
  • vc69
    vc69 Posts: 2,500
    Yeah man, really nice looking job. I totally admire your craftsmanship.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • abes99
    abes99 Posts: 3
    edited June 2010
    Hi all tl lovers,cong for the nice job.
    in my young days i build a tl from atkinson miniline,i still miss the sound and also miss the plannoone seem to know it.
    could you send me dimension please
    many thanks
    if someboby can get hold of the mini line it would be great
    blessing
    abes
  • zingo
    zingo Posts: 11,258
    edited June 2010
    Sadly, the good gent who built that pair of speakers is no longer active on this forum.
  • ShinAce
    edited June 2010
    Not to mention that woofer is likely sold out!
    Abe: If you're asking about the atkinson miniline, you should start a new thread to avoid confusion.
  • Face
    Face Posts: 14,340
    edited June 2010
    zingo wrote: »
    He's back under another user name.
  • FTGV
    FTGV Posts: 3,650
    edited June 2010
    zingo wrote: »
    I snuck back in when the mods weren't looking.:D
  • zingo
    zingo Posts: 11,258
    edited June 2010
  • bikerboy
    bikerboy Posts: 1,234
    edited May 2011
    Its only been 2 years but I am making headway on the RB2 TL design that Fred was so nice to share. I am going to screw the sides on so I can play with the stuffing if needed. I need to glue the front baffle on and bolt it up. I made the back so the x over is protected in the back panel.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    And I thought I took a long time to finish projects.:smile:Lookin good so far.
  • bikerboy
    edited May 2011
    I glued the front baffles on and screwed the side on so I can change the stuffing if needed. I made the back so the crossover is recessed and protected. I listened to them for a while in the mancave and found the lack of bass noticable. I moved them into the garage and placed them in the corners. Now they sound great, nice bass and the tweeter is smooth. They sound much better than the frankenspeakers I used before. They need some hours before I can be critical but I like what I hear so far. Thanks to Fred, as I would never tried to make a folded TL cabinet. Maybe some nice wood veneer or crossover upgrades in the future but I doubt it as they are in the garage for now.
    Bottlehead Eros
    CD: DIY Shigaclone
