Vifa RB2 kit meets mini transmission line
Very nice neat work,some veneer and they should look awesome.I don't see any foam on the panel directly behind the drivers,I assume you added it later?If you scroll down to pic#9 in this link to can see how the original has 2 layers.http://www.positive-feedback.com/Issue45/rmaf2009.htm
I'm using mine in a secondary basement system driven by a vintage Yammy integrated.Having had some more seat time listening my initial enthusiasm has waned somewhat.While the bass is deeper than one can expect from a similarily sized sealed box I do notice it does impart a noticable boxy character to the bass notes in some music.As well because the crossover is deficient in the baffle step compensation dept. I find as you did it sounds more balanced with some boundary reinforcement.
All and all not bad for a $60 pair speakers(excluding wood and sweat equity) as these Vifa drivers are quite good IMO.In fact I think they are capable of alot more if one was to invest some time and effort into a complete crossover redesign.Somthing thats on my to do list.
