New SVS Sub-Equalizer
hockeyboy
Has anyone had experience with using sub EQ's? I see that SVS has a new product that they proclaim makes an incredible difference in leveling out the bass. I run dual SVS subs and am wondering if this is worth the investment.
http://www.svsound.com/products-parts-subeq.cfm
I have to say I am not terribly unhappy with my current bass, but I guess am always looking for ways to improve my system.:D
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
Post edited by hockeyboy on
Looks interesting.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
I was looking at that SVS EQ but I'm still on the fence. I'll wait the unbiased reviews to come it. I did however consult a Audyssey Setup Guide on the AVS Forum (http://www.avsforum.com/avs-vb/showthread.php?p=14456895) that I'm sure most on this site are quite familiar with.
I have to admit that my approach is not too technical as I'm still learning many of the fundamentals. I found the guide very helpful and I'm very pleased with some of the basic changes and noticeable improvements that I've already made in my setup.
I'm curious if anyone else out here has an opinion on this guide?
Onkyo 806
emotiva xpa-2 to fronts ( Rtia9s).
emotiva xpa-3 for center ( csia6) and surrounds (FXi A6)
SVS PB-12-NSD sub
Pro-Ject III Xpressions
Belles Soloist 3 preamp
Bellari VP129 Pre
Pro-Ject USB
A couple of sidewinder ICs, the rest are monoprice
Music Hall DAC 25.2 Mullard E88CC/01
Mac Mini
Samsung LN46A650
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut -
It will help if your room acoustics are affecting your Bass response (Peaks and Nulls and such). If you already have a good flat Bass response, then it may not do much for you.
I have a Velodyne SMS-1 and it has greatly improved some of my sub bass issues. I also use mine to change the EQ adn the Sub's volume on the fly depending on what I'm watching-such as to increase the low freq impact during movies and such.
If you are not sure you need one or not, or want to try the DIY approach, check out Room EQ Wizard at Hometheatershack.com. It's free and you can use it to measure the audio response in your room (and not just for sub bass). That way you can get an idea whether or not you need correction or not. If your sub or AVR already has any kind of correction EQs you may find that you don't eed any further correction. To use REW, at a minimum you need a Radio Shack SPL meter (~$35), and a computer nearby with Line inputs (There are several very inexpensive USB Line in adapters for laptops, if your's doesn't have that capability).
If you find you do need correction and want to take the REW a step further, you can buy a Behringer Feedback Destroyer (~$100) and program it with REW and use it the same way the SMS1 or SVS Sub EQ would.
There is plenty of more detailed info on the HTShack forums I linked to above.
Of course the SVS or Velo SMS-1 is a dedicated piece and is much easier to setup and use-but you pay for that convenience.____________________
Pool: Atrium 60's/45's -
Agreed with MMadden. I also use Velo SMS-1 with excellent results.Shoot the jumper.....................BALLIN.............!!!!!
