HD Sound
Slinger182
I have an Onkyo 606 and a Sharp Aquos BDHP20U player hooked up through hdmi and can't seem to get the hd lights to light up on my onkyo. Am I not getting HD sound? Can I? If so how?
Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505
Post edited by Slinger182 on
also i'm very new. What does it mean when a reply just says "bump"?Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
Are you bitstreaming or running LPCM out of your player? I
f you are using LPCM, then the only lights you will see is multich PCM. Only bitstreaming will show the codec being used.
"Bump" is just a post to bring the thread back to the top of the "recent posts" list.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Slinger, I bumped a bunch of threads last weekend, because some a-hole had posted **** threads, and they were showing as the prominent thread from the main page.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
If I set my player to PCM then my player is doing the decoding, right? Then I do have HD sound? I tried to set it to bitstream but couldn't get any of the codec indicators to light up.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
Hey who can resist homebrew n00b ****!?!?
she swallowed it! lol Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
Slinger182 wrote: »If I set my player to PCM then my player is doing the decoding, right? Then I do have HD sound? I tried to set it to bitstream but couldn't get any of the codec indicators to light up.
I looked at your player specs and it apparently decodes Dolby True HD. No mention of DTS HD-MA. So, assuming your player can decode the HD soundtrack, then setting it to LPCM would mean your player is doing the decoding.
Using bitstream out of your player, the receiver is doing the decoding and you should be able to see it on the display of the 606.
If it is receiving LPCM the display reads "Multich".
If it is receiving say Dolby True HD (via bitstream) the display will show "True HD"
Be sure you have selected the appropriate soundtrack in the disk menu as some discs will default to a "core" or regular DD or DTS soundtrack and the Hi Def track must be explicitly selected.
The Onkyo 606 will decode the HiDef sound tracks so I "always" bitstream via HDMI-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
For HDMI audio out the only 2 choices it gives me is AUTO and PCM (surround)Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
Slinger182 wrote: »also i'm very new. What does it mean when a reply just says "bump"?
Welcome to the Club!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Slinger182 wrote: »For HDMI audio out the only 2 choices it gives me is AUTO and PCM (surround)
Sounds like your player cannot bitstream (which surprises me). So you just need to be sure you are selecting the right soundtrack from the disc menu. The receiver should display multich PCM.
Beyond that, you may want to head over to AVS forums and post your question there in the thread dedicated to your player. I am unsure what else to tell you. Best of luck.
http://www.avsforum.com/avs-vb/showthread.php?t=922602-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Thanks. After going through that huge thread it seems my player is pretty dated though only 2 years old. Which I kind of figured it was one of sharps first BD players and it came free with my TV. BD player is on my short list of upgrades for my HT but not till after new fronts and sub. Definitely enjoying my new hobby thanks in large part to this forum and the helpful people on it.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk PSW505 -
Enjoy Slinger, and welcome to Club Polk, where we can spend your money faster than you can make it, lol.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
