RT-10 speakers
TRAINWATCHER
i would like to know . I have a set of speakers the rt-10 floor standing on back there are two sets of speaker conection one on top one on the bottom why two set? & does it matter which set you use or is there a spical way of setting them up
Post edited by TRAINWATCHER on
They are there if you want to bi-wire or bi-amp them.
Doesn't matter which one you use as long as the brass jumper strap (or a jumper wire) that connects the two together is securely in place. Unless you are bi amping/wireing them. Then the jumper needs to be removed. -
my set of rt10's doesnt have bi amp posts, only a single set...hrmm.TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden -
bumpI refuse to argue with idiots, because people can't tell the DIFFERENCE!
