RT-10 speakers
TRAINWATCHER
TRAINWATCHER Posts: 1
i would like to know . I have a set of speakers the rt-10 floor standing on back there are two sets of speaker conection one on top one on the bottom why two set? & does it matter which set you use or is there a spical way of setting them up:confused:
Post edited by TRAINWATCHER on
  • apphd
    apphd Posts: 1,514
    edited September 2009
    They are there if you want to bi-wire or bi-amp them.
    Doesn't matter which one you use as long as the brass jumper strap (or a jumper wire) that connects the two together is securely in place. Unless you are bi amping/wireing them. Then the jumper needs to be removed.
  • polkanddie
    polkanddie Posts: 224
    my set of rt10's doesnt have bi amp posts, only a single set...hrmm.
    TV- Insignia 46'' LED,1080p,120hz
    Monster Power center hts3600 mk2
    Onkyo tx sr 503
    Rm6600 with 4 sanus stands
    SUB(DIY)
    Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
    extras... RT10's.rti4s.atrium 5's.
    "sticking feathers up your butt does not make you a chicken"-Tyler Durden
  • obieone
    obieone Posts: 5,077
    bump
