1080p projector in the 3000$ range?
bevo
bevo Posts: 306
edited September 2009 in Electronics
What should I go with in the 3000-4000$ range for a 1080p projector. My room will have no light at all in it, and I want a 150 inch screen.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2009
    Look at the Pioneer Elite. They retail for $9000 and was selling as closeouts for $2999. check out videogon.com
  • kcoc321
    kcoc321 Posts: 1,788
    edited August 2009
    If I was going to upgrade I would go with this one:
    Panasonic PT-AE3000U Projector
    > Brightness: 1600 ANSI lumens
    > Resolution: 1080p native
    > Contrast Ratio: 60000:1
    > Dimensions: 18.1in W 5.1in H 11.6in D
    > Weight: 16.1 lbs.
    > Warranty: 1 Year P&L; 90 Days On Lamp
    # > Key Features:
    # Full-HD Optimized Lens Unit
    # Full-HD LCD Panels
    # Detail Clarity Processor 2
    # Cinema Color Management
    http://www.visualapex.com/Panasonic/projector-specifications.asp?for-the=PT-AE3000U
    $2599 on sale
    Have not compared specs to others, but I like mine (AEU900) even thou its only 1080i...
  • mdk5068
    mdk5068 Posts: 204
    +1 to that projector. I saw it in the store when I bought my significantly cheaper projector and it made me feel bad I was buying mine, ha.
    kcoc321 wrote: »
    > Weight: 16.1 lbs.
    # > Key Features:
    $2599 on sale
    Bulls make money.
    Bears make money.
    Pigs get slaughtered.
    You, my friend, are the bacon.
  • Sherardp
    Sherardp Posts: 8,038
    Panasonic is ok, however if your budget is 3000-4000 then look at the JVC RS10. It will smoke the Panny any day of the week. Panny is also LCD projector which means it does not have sealed light path and they are notorious for dust blobs. JVC/Sony are based on LCOS and are sealed so I would definitely look into the RS10 or a Sony VW70. Panny just can't compare to black level of JVC. Even when at it's best the JVC will be brighter than the Panasonic.
    However if you prefer LCD and brightness consider the Epson 6500. Best QC with the Epson as there are not many reports of dust blobs etc. The Panny is a decent PJ, however if you have the funds to splurge go for JVC. The best "CRT" digital PJ on the market. Someone mentioned the Pioneer, however it does not have the brightness to light up such a large screen unless you will be using a Hi-gain screen. Questions, ask.
  • Grimster74
    Grimster74 Posts: 2,577
    I'm guessing now would be the time to put my JVC HD1 up for sale with everyone wanting to go to a projector and it's under $2000:D
  • kcoc321
    Sherardp wrote: »
    Panasonic is ok, however if your budget is 3000-4000 then look at the JVC RS10....
    Sherardo, where did you find the JVC DLA-RS10u for under $4000?
    I looked at the projector site you linked in the other projector thread (>$2000) and that site has them for $4995....
    http://www.projectorpeople.com/projectors/projdtls.asp?itemid=24623&itmname=JVC+DLA-RS10U
    always good to keep ones eye open for good deals....although until Comcast broadcasts in 1080p, (1080i now) doesn't make much difference since I get 1080i already..
    FYI: I have had my Pany for 5years (the AE900U) and I have never had a 'dust blob' issue...course I clean the dust filter at least once every week or two, when I am using it often. (easy 5 min deal)
    Football season must be bringing out all the HT ideas....yeh :p
    Good luck Bevo..either way a 150" 1080p screen will rock...
    you won't want to leave...hehe
  • Sherardp
    kcoc321 wrote: »
    I bought the JVC from AVS store from Jason with full calibration. The price was much lower than that ProjectorPeople has it listed for. Even on Audiogon/Videogon you should be able to find the RS10 under 3500. If the OP is wanting the JVC then I would suggest calling AVS or check those sites I mentioned.
    Panny for 5 yrs then that's good. I can tell you now the 2000/3000U has not been as fortunate. Allot of reports of Blobs being seen right out of the box. So there has been QC issues as of late. Don't get me wrong, every manufacturer has there issues, but I personally would hate dust blobs. I maybe selling my JVC RS10 here shortly and upgrading right JVC releases its new line up. We shall see, and I do decide to sell it will be under 3K, it's calibrated and still has only 484 hrs on bulb. ;)
  • wallstreet
    wallstreet Posts: 1,405
    I just picked up a JVC RS2 from Avsforum for $2100. This projector is awesome. The blacks on the JVC are actually black which provides exceptional depth to the picture quality.
  • Sherardp
    RDS2 is a very nice PJ and it looks like you got one for a very good price. Congrats.
