Tonearm rewire
Fongolio
I want to rewire the tonearm on my Pro-ject 6.9 turntable. The stock wires are barely larger than a human hair and everytime I put a cartridge on or off I break a lead off the wire. They seem impossibly thin to properly conduct the signal. I'm just wondering what some of you have done in this area. I don't want to break the bank but I want wire that is thicker and less prone to breakage. I see silver wire is sometimes used for this. Opinions?
Thanks.
Kelvin
Thanks.
Kelvin
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Post edited by Fongolio on
sorry i can't help you personally brother but Robert here @ http://www.all-electronics.com/ seem's to really know his stuff (about Dual brand anyway's) and if he can't help he may know someone that can
I'm shure TT service is pretty standard across the board so you might be good to go....
i'll be bringing him the 510 and a new 505-3 when i get it
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
Hi Kelvin,
I rewired my denon with Cardas tonearm wire. I preferred it over the solid silver I tried. The Cardas is more balanced with better bass. Its easy to work with but IIRC the insulation was a pain to remove. Scrape and use a hot iron to tin the ends and it works well. Parts Connexion has it. I also have a Hagerman burn-in device called a FryKleaner that will burn-in the wires faster(3 days). Phono wires will take hundreds of hours to settle if you use the cartridge for the signal because of the very low VA. Some use a tuner or cdp for VA to burn-in the phono wire.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
I used Cardas tonearm wire on mine from BritAudio here.
