Tonearm rewire
Fongolio
Fongolio Posts: 3,516
edited September 2009 in DIY, Mods & Tweaks
I want to rewire the tonearm on my Pro-ject 6.9 turntable. The stock wires are barely larger than a human hair and everytime I put a cartridge on or off I break a lead off the wire. They seem impossibly thin to properly conduct the signal. I'm just wondering what some of you have done in this area. I don't want to break the bank but I want wire that is thicker and less prone to breakage. I see silver wire is sometimes used for this. Opinions?
Thanks.
Kelvin
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Post edited by Fongolio on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    sorry i can't help you personally brother but Robert here @ http://www.all-electronics.com/ seem's to really know his stuff (about Dual brand anyway's) and if he can't help he may know someone that can :) I'm shure TT service is pretty standard across the board so you might be good to go....
    i'll be bringing him the 510 and a new 505-3 when i get it :D
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • bikerboy
    bikerboy Posts: 1,239
    Hi Kelvin,
    I rewired my denon with Cardas tonearm wire. I preferred it over the solid silver I tried. The Cardas is more balanced with better bass. Its easy to work with but IIRC the insulation was a pain to remove. Scrape and use a hot iron to tin the ends and it works well. Parts Connexion has it. I also have a Hagerman burn-in device called a FryKleaner that will burn-in the wires faster(3 days). Phono wires will take hundreds of hours to settle if you use the cartridge for the signal because of the very low VA. Some use a tuner or cdp for VA to burn-in the phono wire.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • hearingimpared
    hearingimpared Posts: 21,136
    I used Cardas tonearm wire on mine from BritAudio here.
