Computer Problem
VR3
How would you change what looks to be a default setting of read only on all files back to where you can save again?
It is like the entire computer is on read only and you cant save a dang thing anywhere, is there a place on the control panel or somewhere that this setting can be altered or somewhere? Dad is getting frsutrated and we can't figure it out. All help is welcome, thank you in advance.
Computer is XP Home...
control panel
user accounts
select the account
change the account type
select computer admin
click change account type
that's my best guess. -
Sounds like a permissions issue.
Were you messing around in any of the user settings?
Try what was suggested above. Also, did you try rebooting? Hey, if all else fails...reboot.
Let us know. We're cheaper than Microsoft support.
JohnNo excuses! -
Trey - If your question cannot be answered here, use:
www.dslreports.com
They have a Microsoft forum, and a very regular posting pattern.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Did not work, thanks for the help though...anyone else?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have a computer problem.......
Windows ME
Start->All Programs->Accessories->Windows explorer
Right click on C: drive, select properties. Click on tools tab, under error checking click on check now. Check both boxes. Click start, ( it should give you a warning about restarting) then reboot. Depending on how large the drive is it may take a while.
By the way, does it give you an error message if you try to save something to the harddrive? -
Windows ME
Rs i have a solution, windows XP, send me your address and yo get a instant free copy of windows xp pro and windows xp office pro, for evaluation only LOL... or to install.. Its labor day im in a good mood.. take the plunge.. hehe!!!MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Windows XP?
Let's see....
Physical Memory - 128MB
uhhhh.......hmmmm.....oh well, memory comes cheap these days :cool:
And you're email is?
edit - sorry brett, I know you wanted to give me a free copy too. hehe -
Thank you, this worked (or so my Dad said - not really sure, he sent me an email but I can't check it....I will confirm once I know)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
