Computer Problem
VR3
VR3 Posts: 29,427
How would you change what looks to be a default setting of read only on all files back to where you can save again?
It is like the entire computer is on read only and you cant save a dang thing anywhere, is there a place on the control panel or somewhere that this setting can be altered or somewhere? Dad is getting frsutrated and we can't figure it out. All help is welcome, thank you in advance.
Computer is XP Home...
  • wlrandall
    wlrandall Posts: 440
    edited September 2003
    control panel
    user accounts
    select the account
    change the account type
    select computer admin
    click change account type
    that's my best guess.
  • Strong Bad
    Strong Bad Posts: 4,278
    Sounds like a permissions issue.
    Were you messing around in any of the user settings?
    Try what was suggested above. Also, did you try rebooting? Hey, if all else fails...reboot.
    Let us know. We're cheaper than Microsoft support.
    John
    No excuses!
  • dorokusai
    dorokusai Posts: 25,576
    Trey - If your question cannot be answered here, use:
    www.dslreports.com
    They have a Microsoft forum, and a very regular posting pattern.
    VR3 Posts: 29,427
    Did not work, thanks for the help though...anyone else?
  • rs159
    rs159 Posts: 1,027
    I have a computer problem.......
    Windows ME :(
  • polktycoon
    polktycoon Posts: 35
    Start->All Programs->Accessories->Windows explorer
    Right click on C: drive, select properties. Click on tools tab, under error checking click on check now. Check both boxes. Click start, ( it should give you a warning about restarting) then reboot. Depending on how large the drive is it may take a while.
    By the way, does it give you an error message if you try to save something to the harddrive?
  • faster100
    faster100 Posts: 6,124
    Windows ME :(
    Rs i have a solution, windows XP, send me your address and yo get a instant free copy of windows xp pro and windows xp office pro, for evaluation only LOL... or to install.. Its labor day im in a good mood.. take the plunge.. hehe!!!
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • rs159
    rs159 Posts: 1,027
    Windows XP?
    Let's see....
    Physical Memory - 128MB
    uhhhh.......hmmmm.....oh well, memory comes cheap these days :cool:
    And you're email is?
    edit - sorry brett, I know you wanted to give me a free copy too. hehe
    VR3 Posts: 29,427
    Thank you, this worked (or so my Dad said - not really sure, he sent me an email but I can't check it....I will confirm once I know)
