Is this a problem?
TouchOfEvil
TouchOfEvil Posts: 967
edited August 2009 in DIY, Mods & Tweaks
I bought two power cords off the bay for a really cheap price. They are dh labs cords but they are terminated with...
(Marinco Hospital grade 15amp on the outlet end, 10A Marinco on the other end)
Will it hurt anything having a 10A end on the side that goes into the unit?
Should i replace it or maybe even both?
Thanks.
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
    treitz3 Posts: 20,085
    edited August 2009
    Not unless you are pulling more than 10 amps.
  • TouchOfEvil
    edited August 2009
    gotcha, thanks.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
