Clearaudio Clever Clamp
Fongolio
Fongolio Posts: 3,516
edited August 2009 in 2 Channel Audio
I picked up one of these in Edmonton Alberta at a high end audio shop for use on my bedroom turntable. It works very well and is a genuine clamp, not a weight. Simple but very effective and very inexpensive. I got it for $27.00 cdn funds. Here's a link...
http://www.elusivedisc.com/prodinfo.asp?number=CLEACCLAMP
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Post edited by Fongolio on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2009
    Is it a reflex clamp?
  • Fongolio
    edited August 2009
    Simple friction. Just press it on the spindle and it very effectively presses down on the record. I was quite impressed with how well it pressed using only friction with the spindle.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • hearingimpared
    edited August 2009
    Does it flatten the record out to the lead in bead?
  • Fongolio
    edited August 2009
    Yes, but I haven't tried it on any really warped records. But even those my Pro-ject screw on clamp doesn't always fix.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • hearingimpared
    edited August 2009
    I'm glad you are enjoying your new toy.
  • Fongolio
    edited August 2009
    In the store I spotted it on a Clearaudio Master Reference table and asked them about it. They claim it works as well on most LP's as the much more expensive Sota reflex clamp they sell in their own store.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
