Clearaudio Clever Clamp
Fongolio
I picked up one of these in Edmonton Alberta at a high end audio shop for use on my bedroom turntable. It works very well and is a genuine clamp, not a weight. Simple but very effective and very inexpensive. I got it for $27.00 cdn funds. Here's a link...
http://www.elusivedisc.com/prodinfo.asp?number=CLEACCLAMP
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Post edited by Fongolio on
Is it a reflex clamp?
hearingimpared wrote: »Is it a reflex clamp?
Simple friction. Just press it on the spindle and it very effectively presses down on the record. I was quite impressed with how well it pressed using only friction with the spindle.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Nitty Gritty 1.5FI RCM -
Does it flatten the record out to the lead in bead?
hearingimpared wrote: »Does it flatten the record out to the lead in bead?
Yes, but I haven't tried it on any really warped records. But even those my Pro-ject screw on clamp doesn't always fix.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
I'm glad you are enjoying your new toy.
In the store I spotted it on a Clearaudio Master Reference table and asked them about it. They claim it works as well on most LP's as the much more expensive Sota reflex clamp they sell in their own store.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
