SRS 142/17 Driver
pablo_rodz
Like the title says, I'm looking for (1) SRS 142/17 Driver.
I recently bought some vintage bookshelve spreakers (don't know the model) and a few days ago one of the drivers stopped working:(
Any help will be greatly appreciated!
HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
Living Room:
Post edited by pablo_rodz on
That is not a part number for a Polk driver.Political Correctness'.........defined
President of Club Polk -
:rolleyes:
That number is in the side of the driver... Do I have to remove the driver and look at the back of it?HT:
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
yes.. the number will be on the back of the magnet...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Why the Roll Eyes?Political Correctness'.........defined
Why the Roll Eyes?
Because I though about removing the driver, but I was lazy and didn't do it.... I was like nah! that's it, that's the number!...
obviously I was wrong. I guess I should have used :mad:HT:
Living Room:
pablo_rodz wrote: »Because I though about removing the driver, but I was lazy and didn't do it.... I was like nah! that's it, that's the number!...
The speakers are at work, All I know is that they were built in 1983, and that the have one tweeter, and one 6 1/2" driver, round binding post/crossover plate.
I will have to wait until Tuesday to get the info!HT:
Living Room:
BTW...
So what does that SRS 427/17 means?HT:
Living Room:
Gotcha.So what does that SRS 427/17 means?
No idea.Political Correctness'.........defined
The SR 142/17 on the rubber surround is just an oem designation for the surround itself....it has nothing to do with a polk part number...I have no less then four 6 1/2" drivers here from 4 different manufacturers with the exact SR 142/17 designation on the rubber surround ( I can see Eton...Vifa...Polk....and the 4th I cant remember the raw drivers name...but its my in wall's from ACI/Audio Concepts )
Looking for correlation in Vifa's pdf's for the drivers, I have some of their older 6 1/2" woofers that use the 17W designation in the part number and they happen to have an OD of 170mm. Their new 7 inch woofers have 18W in the part number and they happen to be 180mm OD.
I also have some 5" vifa's in my ACI AV-1's....their rubber surrounds read SR 110/14 ......their OD is 140mm
So it looks like the 17 is just showing that the rubber surround flange fits/glues onto a frame of 170mm +/-
The preceding number 142 happens to equal 5.6 inches.....I grabbed my caliper and just measured the OD of the rubber surround only ...not including the flange part that glues to the frame....it was 5.6 inches exactly
So the surround itself has an exact OD of 142mm......and with the generously wide flat glueable area of the surround past that 142mm....it allows it to be used on frames measuring around 170mm...probably why they dropped the zero because with that wide glueable area it would work just fine with a 167mm frame or even a 173mm frame. Looks like they didnt want to label/limit it to just 170...so they marked it as 17.
S R 142 / 17
Surround Rubber Surround OD 142mm 170mm frames +/-
I looked at my CRS+'s ( Both pairs ) ....SRS's....2.3's....Monitor 10's....SDA 2b's....hell even the new 5jr+'s....every single polk 6 1/2" of that vintage had SR 142/17 on the surrounds....even the 6513's and the 6 1/2" radiators in the 5jr+'s ( Such cute little radiators
)The first rule of Fight Club is you don't talk about Fight Club -
Thanks for the info. I'll check the model number next week, and maybe post pics too.HT:
Living Room:
Ok, So I checked and my speakers are Monitors' 4, Built on 5/5/83.
The driver is **6500, can't recall the letters maybe MS6500? I took a picture, but it came out blurry...
Everything looks original, tweeters, drivers and crossovers. What upgrades can be done to this speaker?HT:
Living Room:
MW6500's can be found here sometimes or you can try E-Bay. Maybe Polk has them too and are about $50.00 each freight paid.
ThanksHT:
Living Room:
