Any specific settings or setup when I get my sr 806??
Polkie918
Should get it monday but possibly and hopefully saturday....
any specific way I should set it up or change any settings other then using the MIC? look in my sig for speakers I have.
Thanks alot
Thanks alot
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
Post edited by Polkie918 on
I would start by running Audyssey, and see what it sounds like. It does a pretty good job of setting things up for you, and you can fine tune it from there if you aren't happy with the results. I have an 806 and let me tell you from experience, you will not be dissapointed. IMHO, for what the 806 does, it is hard to beat at the price it is going for these days.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
+1 what wutadum said. The auto calibration gives you a great starting point that you can fine tune and tweak from. Make sure there are no background noises when running the auto setup.
jrpanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
