Any specific settings or setup when I get my sr 806??
Polkie918
Polkie918 Posts: 245
edited August 2009 in Electronics
Should get it monday but possibly and hopefully saturday....
any specific way I should set it up or change any settings other then using the MIC? look in my sig for speakers I have.
Thanks alot
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Post edited by Polkie918 on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited August 2009
    I would start by running Audyssey, and see what it sounds like. It does a pretty good job of setting things up for you, and you can fine tune it from there if you aren't happy with the results. I have an 806 and let me tell you from experience, you will not be dissapointed. IMHO, for what the 806 does, it is hard to beat at the price it is going for these days.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • superjunior
    superjunior Posts: 1,632
    edited August 2009
    +1 what wutadum said. The auto calibration gives you a great starting point that you can fine tune and tweak from. Make sure there are no background noises when running the auto setup.
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
