Denon 2803 Calibration
acdds
Anyone know how to calibrate the 2803 using a DVD. I have the on screen display set to Video 1 on my TV. The DVD player is set to the component input which is Video 4. So I can't see the DVD screen while adjusting speaker levels using the OSD. Also, how do you adjust the speaker levels with out using the internal noise generator? I can't find a menu to adjust them without using the internal generator. This is driving me nuts! Any advice would be greatly appreciated!
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
If the 2803 is anything like the 3803, the center button of the remote allows you to toggle through and adjust the channel levels for all 8 speakers.
The AVR display will show the channel level for each speaker so you can use the TV screen for the DVD.
If the calibration DVD is a DD or DTS disc (most are) using the remote will alter the master channel level settings in the set-up menu. You have to make sure the set-up menu is unlocked before you start.
If your AVR has Personal Memory Plus, then you can also have customized channel level settings for various inputs like Stereo, Direct, Pure Direct, Neo-6, 7 channel "stereo", etc. Adjusting these with the remote will NOT alter the master set-up menu settings since these are not DD or DTS sources.
Hope this helps!
Doc"What we do in life echoes in eternity"
SVS -
which level Denon has the THX cert. ? on the lowest level.. 4802? 4803? and do you need the thx ex? MY integra has that plus a few other THX functions that i want if i ever upgrade my receiver.. future future planning.. nothing soonMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Thanks for the info Doc! That is what I needed to know.Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
