quick question about amp power...
Polkie918
Ok....so the onkyo 606 has 90wpc........the 806 has 130wpc...
I have the 606 and id I have it set at 60 volume....and then buy the 806 and have it set at the same exact volume 60....is it gonna be louder cause of the extra 40 watts or just more clear clean sound??
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
Post edited by Polkie918 on
The volume number setting is meaningless. You need to have an SPL meter and set each amp to produce the same sound pressure level. All things being equal, the higher powered amp should be clearer than the lower powered amp at the same SPL.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Don't get rid of one AVR and purchase another one to gain amp power.... If you want a more powerful amplifier, get an external amp. Buy another reciver for a differnet sound (if I differnet brand), different features (pre-outs come to mind) or a better interface.
Any AVR (almost) over about 80 watts will have really close to the same max volume as any other.
Just my opinon on it...
Well in this case he has to get a new receiver in order to get the preouts he needs for separate amplification.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
The 706 would have everything you need (preouts) and be a bit cheaper than the 806.Mains - LSi9's
Center - LSiC
Surround - pair of TL3's
Amplification - Parasound 2125
AVR - Onkyo 706
CD/SACD - Onkyo DV-SP506
SUB - MartinLogan Abyss
55" Panasonic Viera TC-P55GT30 3D
Bluray - DMP-BDT310 Panasonic -
Agreed the 806 or the 706 would be a nice update, only due to have pre amp outputs. These pre amp outputs would be needed to update your system again in the future.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
yea tigerdirect has a good deal on a open box sr706 (just under $400).........is there any other receivers that would compare for around $400 that had all the new audio and have at least hdmi in's.....I know yamaha is a good one too.....
so going from my 90wpc up to 130wpc isnt really going to make a big difference?
what would u all recommend me get....model numbers please and I will look them upFronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV -
power wise - no.so going from my 90wpc up to 130wpc isnt really going to make a big difference?Mains.............Polk LSi15 (Cherry)
This receiver has 4 HDMI inputs and 1080p upscaling along with 7.1 audio preouts. I think the only difference with the 806 is less power, 100w per channel. Its a good option if you are looking at an external amp.Mains - LSi9's
Center - LSiC
AVR - Onkyo 706
what kind of money will i need to sink into an external amp...i dont have alot of moneyFronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
Did you see this?
http://www.polkaudio.com/forums/showthread.php?t=87353
Take the extra $250 and buy an amp and your set. -
I did hear a difference when I moved from my 605 to my 875 (140 wpc). Many believe the 806 is a great bargain. If you're budget constrained, I'd go for the 806 and hold off on the amp. While you will probably want a separate amp in the future, your speakers will like the additional power in the meantime. Having a powerful receiver is a nice back-up, even if you get one (or more) amps.MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
It wasn't that you need an amp today, but are able to add an amp later if you wished too. Buying an AVR today with pre amp outputs saves you cash later.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
