quick question about amp power...
Polkie918
Polkie918 Posts: 245
edited August 2009 in Electronics
Ok....so the onkyo 606 has 90wpc........the 806 has 130wpc...
I have the 606 and id I have it set at 60 volume....and then buy the 806 and have it set at the same exact volume 60....is it gonna be louder cause of the extra 40 watts or just more clear clean sound??
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Post edited by Polkie918 on
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2009
    The volume number setting is meaningless. You need to have an SPL meter and set each amp to produce the same sound pressure level. All things being equal, the higher powered amp should be clearer than the lower powered amp at the same SPL.
  • McLoki
    McLoki Posts: 5,231
    edited August 2009
    Don't get rid of one AVR and purchase another one to gain amp power.... If you want a more powerful amplifier, get an external amp. Buy another reciver for a differnet sound (if I differnet brand), different features (pre-outs come to mind) or a better interface.
    Any AVR (almost) over about 80 watts will have really close to the same max volume as any other.
    Just my opinon on it...
    Michael
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2009
    Well in this case he has to get a new receiver in order to get the preouts he needs for separate amplification.
  • dorourke07
    dorourke07 Posts: 298
    edited August 2009
    The 706 would have everything you need (preouts) and be a bit cheaper than the 806.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2009
    Agreed the 806 or the 706 would be a nice update, only due to have pre amp outputs. These pre amp outputs would be needed to update your system again in the future.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Polkie918
    edited August 2009
    yea tigerdirect has a good deal on a open box sr706 (just under $400).........is there any other receivers that would compare for around $400 that had all the new audio and have at least hdmi in's.....I know yamaha is a good one too.....
    so going from my 90wpc up to 130wpc isnt really going to make a big difference?
    what would u all recommend me get....model numbers please and I will look them up
    Fronts- RTi8
    Center- CSi5
    Rears- FXiA4
    Sub- Velodyne 12"
    Onkyo TX-SR806
    Ps3
    Xbox 360
  • McLoki
    McLoki Posts: 5,231
    edited August 2009
    Polkie918 wrote: »
    power wise - no.
  • dorourke07
    edited August 2009
    Polkie918 wrote: »
    This receiver has 4 HDMI inputs and 1080p upscaling along with 7.1 audio preouts. I think the only difference with the 806 is less power, 100w per channel. Its a good option if you are looking at an external amp.
    Mains - LSi9's
    Center - LSiC
    AVR - Onkyo 706
  • Polkie918
    edited August 2009
    what kind of money will i need to sink into an external amp...i dont have alot of money
    Fronts- RTi8
    Center- CSi5
    Rears- FXiA4
    Sub- Velodyne 12"
    Onkyo TX-SR806
    Ps3
    Xbox 360
  • kcoc321
    kcoc321 Posts: 1,788
    edited August 2009
    Did you see this?
    http://www.polkaudio.com/forums/showthread.php?t=87353
    Take the extra $250 and buy an amp and your set.
  • NewHTguy
    NewHTguy Posts: 584
    edited August 2009
    I did hear a difference when I moved from my 605 to my 875 (140 wpc). Many believe the 806 is a great bargain. If you're budget constrained, I'd go for the 806 and hold off on the amp. While you will probably want a separate amp in the future, your speakers will like the additional power in the meantime. Having a powerful receiver is a nice back-up, even if you get one (or more) amps.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • disneyjoe7
    edited August 2009
    Polkie918 wrote: »
    It wasn't that you need an amp today, but are able to add an amp later if you wished too. Buying an AVR today with pre amp outputs saves you cash later. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
