Adcom ace-515 ac enhancer
Toolfan66
Toolfan66 Posts: 18,048
edited August 2009 in Electronics
Anybody use one of these?
Post edited by Toolfan66 on
  • fbm211
    fbm211 Posts: 1,488
    edited August 2009
    I had one long ago.Its ok for low power systems I guess as long as you can get one for around 50.00...Otherwise I would go with something from PS audio like one of those UPC units if you can find one.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • lakesailor
    lakesailor Posts: 319
    edited August 2009
    It's got more bite than you think...it will run 750 watts average output and is decent design. I had good luck with mine and the delay on/off for your amps is handy as well. For the money they sell for they are a good buy used.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited August 2009
    I was thinking about getting one of those, but ended up getting an APC H10.
    I had several people advise me of the possibility that the ACE-515's could get a bit worn out over time. The surge protection circuitry ages and can become a lot weaker.
    Personally, I'd pass on it and get something more up to date. The APC H10/H15 are both excellent units, and can be had for real cheap.
    I don't have any experience with any of the PS Audio units, but they get real good press.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2009
    Haven't used the Adcom but look into Monster, Belkin, or APC.
  • POIDOG
    POIDOG Posts: 391
    edited August 2009
    Uesd one for many years, bought brand new from "The Good Guys", now defunct.
    Anyhow I digress, never had a problem with it. Amp delay feature worked really well.
    I upgraded after a few years for video reasons (excuses). Ok if your getting a good deal
    Bill
