ID help please
CoolJazz
Lots of info on them....just not the model. And I did go through the schematics and couldn't find what seemed like a match. So pardon the simple question!
And the rear labeling...
Any idea? Thanks much!!
CoolJazz
CoolJazz
A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
Post edited by CoolJazz on
SDA-1. NOT 1A. Later model too.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
SDA 1,, interconnect cable come with it? How much are they aslking? Good luck.JC approves....he told me so. (F-1 nut)
If no interconnect cable, http://cgi.ebay.com/Polk-Audio-SDA-speaker-cable_W0QQitemZ330352859513QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item4cea909979&_trksid=p3286.c0.m14polkaudio Monitor 5 Series II
Later production SDA 1's with SL-1000 tweeters.
They look like they're in pretty good shape.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Thanks for all the replies and information!! Much appreciated!!
These are actually a friends. He'd traded into them and I don't think will be keeping them or if he did, would be a second or third system. He wasn't sure if they were working right and I said I'd like to look them over and check them out. A listen in my own system...that's not all bad! But it's been too long and I need to get them going and cleared out.
Should they become available...I'll be sure and let the forum know!
Thanks again!
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
