Epson 6100 vs Panny AE900U
PSOVLSK
PSOVLSK Posts: 5,390
edited August 2009 in Electronics
Will the improvement in the Epson over the Panny be significant?
Sit 13' from 120" screen in a dedicated HT with dark navy blue walls ceiling and carpet.
Screen is homemade using blackout cloth (white fabric).
I have a blu-ray and DirecTV HD.
I think that's all the factors that need to be considered.
Thanks in advance for your opinions and experiences with either PJ.
Post edited by PSOVLSK on
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited August 2009
    I would say yes, When I was looking for a new PJ this site helped me alot, here you a link compare the 6100 to some of the newer 1080p projectors.
    http://www.projectorreviews.com/epson/home-cinema-6100/image.php
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2009
    Definitely go with the 6100. You surely won't regret it either. Epson makes very nice PJ's so the 6100 should perform well for you.
  • Sherardp
    edited August 2009
    Also I forgot to add, with such a huge image size you will surely notice improvement with the 6100. I sit 13 feet from 126" screen and the image via the Carada is stunning. You may also want to try some screen samples as you will probably notice more improvement with dedicated screen. Just a thought.
  • PSOVLSK
    edited August 2009
    Sherardp wrote: »
    I considered this also. A screen may have to be my next upgrade, but it might be a tough one. The image is so nice on the $35 screen that I'm not sure I can convince the little lady that we need a new screen:p
    BTW, I did pick up a 6100 and though I haven't had but about 20-30 minutes to spend with it, initial impression is that the picture is significantly better. Very happy with the purchase and I appreciate you guys pushing me over the edge to go ahead and buy it.
