Model 10?!
  • Bobsama
    Bobsama Posts: 526
    edited August 2009
    Quagh wrote: »
    Sorry, didn't mean the tweeters, the larger woofers.
    Mine say model 6600X but after swapping them out I have to now wonder if there may be a cross over issue as the rattling has now gone away and the static seems to be from the tweet. (could've just been that scratchy Marvin Gaye - What's Goin' On song too!) Bad choice but I was rushing.
    Had seen an earlier post that showed these used MW6503 but that's not what I see in mine.
    Thanks in advance for all the help guys! I'll be leaving tomorrow to spend weekend wi family before school starts. I'll be back here Sunday or Monday tho'! Just not enough hours in the day! Kids, bills, stereos. Crazy but fun!
    Well then that further backs up my little theory that you got early-production Model 10B's. Anyways--there's really not much you can do. Try to figure out if the woofer is actually shot or if the woofer or cabinet is resonating. I think Monitor 10's use the same midwoofers all around, but only MW6503's are very common. You can try contacting Polk about cabinet design and compatibility. It's a lot of work to repair or entirely refurbish a pair of vintage speakers.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • Quagh
    Quagh Posts: 11
    edited August 2009
    Any particular department, person or number I should use of just go through this site?
    Pioneer Silverface Stuff (need some Sanny's) Anything Old and Solid State.
    Dahlquist, HPM-100, Polks, Wharfedales, AR's, Advents, Vegas, Fraziers, etc.
    Turntables
    Looking for Albums, Always!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited August 2009
    Quagh wrote: »
    Scroll up to the top of the page that you're looking at right now. There will be a phone number there to call...that's the CS hotline.
    1-866-764-1801
    They're open Monday through Friday, 9 am to 10:30 pm EST.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Bobsama
    Bobsama Posts: 526
    edited August 2009
    Quagh wrote: »
    Helen Yarbor at 1-800-377-7655
    She deals with replacement parts.
    F1nut Posts: 51,782
    edited August 2009
    Bobsama wrote: »
    Your theory? I do believe it was I that made that suggestion first. However, in light of the fact that he has MW6600X drivers, dated 1984 I'd have to say that my suggestion about them possibly being early 10B's is dead wrong. It's looking more like they are early production 10A's.
    That comment doesn't make any sense. The 10A's are suppose to use MW6501's. The 10B's use MW6503's.
    Peerless and SL1000's used a flat shiny plate with the marks at an angle.
    The Peerless faceplates are flat black. Only the SL1000 used a shiny sliver faceplate.
  • salasg
    salasg Posts: 172
    edited August 2009
    I recently purchased Monitor 10B's as well. Had issues with two fo the drivers. Turns out they were also MW6600x with SL1000 tweeters.
    Gus
    F1nut Posts: 51,782
    edited August 2009
    In that case, they were not 10B's.
  • salasg
    salasg Posts: 172
    edited August 2009
    Will post pictures to get your opinion and set myself strait. I would like to know myself if they are 10A's or 10B's. Thanks
    Gus:)
  • geppy1
    geppy1 Posts: 3,076
    edited September 2010
    Wow i just noticed this Alll over the map. You can take this to the bank (with some slight crossover and exceptions)
    Early 10 1977 to 1980 6500s (gray carboard around drivers ) Danish Peerless marked 7514____
    10A 1980-81 to 1983 6500 (no carboard around drivers ) US made Peerless (different versions) marked 5514______ SN 80,000 -120,000 about Also cabinetr change
    Early 10Bs 1984 to late 1985 6600X or 6501s with silver faced SL1000 tweeter with clear dome marked 5514______
    Late 10Bs 1986-1988 6501s or 6503s with SL2000 There also was a cabinet change
    Hpe this helps When in doubt take stuff out and check dates keith
