Good Price on Banana Clips anyone??
Pauly
So i want to hook up my speakers with the Monster Banana Clips on my setup. I need 22 of them to complete the task. I have only found them in packs of 2 @ 19.95. Thats 11 x 19.95 = 219.45 + Tax. The wife will never go for that especially since i just bougt a pair of rti28's. Anyone know of someone selling them in bulk @ a discount rate? Or maybe something just as effective just not as pricey? Any input would greatly be appreicated.
Rti70's Fronts
Csi30 Center
PSW404, PSW350 Stacked (Subs)
Rti28's Rear
Onkyo TXSR500
Rti70's Fronts
Csi30 Center
Rti28's Rear
Onkyo TXSR500
Life without music would♭
Post edited by Pauly on
I went through the same crap. Go to Radio Shack. They are less than $1 per pair. They even sell black and red ones. They also have the red double plugs that I like, just mark the ground side black with a sharpie. You need to use a Moster Cable Sharpie however, because the sound will be degraded and fuzzy.
Personally I think the Moster ones are lousy. I couldn't even get them to stay on their own wire!
Ahhhh. So with Monster you are just paying for the name? That is much much better. Did not think RS sold em. ThanksLife without music would♭
So i just picked up the RS Banana Clips (Pic should be attached) from above link, and now they look a little confusing because the top part unscrews from the bottom part. ??? There is a hole on the bottom where the wire would (should) go but then why would it unscrew?? Is this for locking the wire in? Normally i can figure stuff like this out but dont wanna screw anything up.
Class, Anyone?
SpasticLife without music would♭ -
Those suckers were tricky, but you can't hurt them. The wire goes through the threaded nut and into the center hole and out the end hole a little bit. There is a little hole off center I think. When you tighten the nut it clamps on the wire that sticks out. I hope your banana plugs are the same design. I like the double plastic ones better because you use a screw driver to tighten the wire directly. Low resistance connection. The plastic ones look like **** however but they do the job. Radio Shack has many banana plug types I think.
I have Monster Cable on everything except my banana clips. I found the acoustic research banana clips better because you actually have to screw them down with a screw driver to the speaker wire, a much better connection IMHO. Not only that they are 1/3 the cost. Heres a link to BB.
http://www.bestbuy.com/site/olspage.jsp?id=1051384702857&type=product&productCategoryId=cat08055Money Talks, Mine says Goodbye Rob!!!! -
Damit! This has been a night mare between the Monster Angled crimps and auto locks and now these.. I just want a good connection. Thanks for the help. Hope RS is good about returns on open items.....:)
As always Thanks,
It is a sad day that you can't get simple banana plugs today. I couldn't believe the price they wanted for banana plugs at the Hi Fi stores. Way back when (1960's) everone sold them and used them on electronic test equipment. I finally ordered 50 heavey duty banana plugs from an electronic supply store through the company I worked at. They cost me $.50 each! It sounds like a conspiracy to me-can't go to the moon today, lost technology again.
It is worth it to convert to the banana plugs however, saves much time when changing wires.
PS Make sure you tighten down all the plastic nuts on the speakers, sub and amplifier when using the banana's. The nuts will rattle with load music. The nuts don't need to be tight to make a good electric connection with the banana plugs. I forgot about this and went nuts trying to locate the rattling noise. -
Have you had problems with the rubber on the AR's deteriorating? I had some Monster pins in the past that the rubber boots got all cracked and brittle, probably from the heat of the gear. I was considering the RS ones but if these are better and less expensive................
are there special ones for the back if the amp to bi-wire my rti70's since you cant fit 2 plugs in one hole?Life without music would♭
You're supposed to be able to get both wires into one plug. Don't know for sure. I've never tried it as none of my speaks are bi- wireable. -
THESE Monster locks work great!!! and easy to juse
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3042873866&category=32838MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I tried using the Monster Angled Crimps but there is limted room to fit 2 in one hole on the back of my onkyo....seems like i would run into the same prob with those about haveing limited roomLife without music would♭
you use stackable banana's, and stack on each other.. or bare wire on the amp side as i do, no need to use connectors on the receiver side when you don't change wires everyday.. speaker side is nice when you move speakers or what ever..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
So on the way home from work i decided to swing back by RS and look at other options so i can biwire other then just stright wire...i seen these on he shelf (see attached) and picked them up and it was the quickest clip i have tried yet and the width between the +/- fits right in the terms on the back of my amp.....oh and the RS banana clips (pic posted above) were a little tricky but were a good alt to spending 20 clams per 2 vs 5.99 per 2. Thanks guys.
Spastic
stackable just like i said,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
didnt know these were the stackable ones...i like pics
Thanks though Life without music would♭ -
Make sure that they are wide enough to fit into both banana clip holes. I bought those same plugs and they were too narrow to plug into the back of my Denon 2803. I did not, however, try them in any of the polk speakers that I have. Radioshack didn't give me any problems returning them either.
Edit: sorry I didn't read your entire post, glad they fit for you!
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's -
spb,
I too went the RS dual banana route. Quick and clean swaps, yet very secure. But as warned aboce post spacing on equipment does have to accpet dual b's. Today this is the norm though.More later,
Tour...
Vox Copuli
i know we all love pics in here. here is what i did. I have my RT800i's biwired. monster Z2
it came with those crazy pin connectors. that broke the very first day in tried to connect them. they are better suited for spring loaded clips instead of binding posts.
so i had to change out the ends.. on a biwire of course you're looking a quite a few ends to change over. So i got monster master lock pins then put the monster banana plugs on the ends of those. so you're like paying twice just for the connectors. once for the monster lock, then for the banana plug. it's pure and simple highway robbery.
cost for two front RT800i's
monster master pin locks. 4 (pkgs) x $19.99 = $80
monster banana plugs. 4 (pkgs) x $12.99 = $52
total = $132 + 8.2 % tax.
crikey!PolkFest 2012, who's going>?
Note the jumpers still in place, yet the speakers still stand.
Still taming the sound, db, I take it...More later,
Tour...
Vox Copuli
Some reason this isnt a good selling point for me....
"PERFECT FOR BOSE SPEAKERS"- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
thats a great price on locks regardless of the clueless sellers examples of use
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
yes indeed. i kept the jumpers in place. I tried a 14guage wire jumper.. but didn't notice any difference.. so I kept the jumpers that come with the speakers. To me they have a cleaner look to em.
The extreme highs that i had, have been easier to listen to when i replaced the jumpers. After many months of tweaks.. i came to the conclusion that the brightness problem i was having is coming from the receiver. Not much I can do about it till i replace it either next year or the following year. this was after I played around with different, wires, interconnects, amps, settings, speaker placements.. etc. It's tuned now to a pretty desireable tone where your ears don't bleed anymore.
AlPolkFest 2012, who's going>?
Class, Anyone?
Spastic
Strip about 3/8" of insulation off the wire, then feed the wire through the bottom piece. Fold the un-insulated portion of the wire backwards (like you were flaring it out) over the outside side of the lower piece. Be sure not to go past the threads. Screw the top w/ the banana end down. Solid firm connection! I have them for my rig and have had plenty of good sucess.Damn....8 lines...I've gotta put my sig on a diet now.... -
I have the "paired" banana plugs. I picked up some Rockford Fosgate ones in the car audio section. They are built very solidly - much better than the other stuff I found. They were $6 a pair.
The Radio Shack ones look pretty well built too. Great pics!
