What is your trick
Willow
Willow Posts: 11,258
edited August 2009 in The Clubhouse
I need to know what you guys do, if anything. I'm tired of getting to work with a wrinkled shirt due to the seatbelt. No I won't buy the wrinkle free shirts either.
Post edited by Willow on
  • Pauly
    Pauly Posts: 4,519
    edited August 2009
    Spray bottle
    Half Fabric Softener / Half water. Mix
    Spray.
    Enjoy
    Pauly
    Life without music would
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2009
    THey also sell a spray that is most likely what Pauly just described, but marketed better. :)
    http://www.downy.com/en_US/products/wrinklereleaser.jsp
  • concealer404
    concealer404 Posts: 7,440
    edited August 2009
    I drive to work without a shirt, and put it on in the parking lot.
    If i'm feeling REALLY ambitious and want to walk in like the perfect employee, i'll shave using my side mirror.
  • venomclan
    venomclan Posts: 2,467
    edited August 2009
    I would hate a job that required shirts and shoes, that is why I became a porno star.
  • Pauly
    Pauly Posts: 4,519
    edited August 2009
    bobman1235 wrote: »
    Mine is more cost effective :) Therefore no flimflam :D
    Pauly
  • edbert
    edbert Posts: 1,041
    edited August 2009
    If I ironed the shirt and it gets wrinkled because of the seatbelt, who cares. The only way I know to fully prevent it is if you have your shirts dry cleaned and get them starched. It doesn't have to be heavy starch either, light to medium works just fine.
    You might not think about it, but the back of your shirt is probably severely wrinkled as well from sitting in the seat!!! Ultimate solution, ride a bike to work. :)
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • Willow
    edited August 2009
    Pauly wrote: »
    Pauly
    I'll check it out, thanks. Or I'll just put my shirt on when I get to work.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2009
    Willow wrote: »
    Hummm, shirt wrinkled due to seat belt? Never really had that problem (the back of the shirt sure...). You must be using starch, are you (that I can see)? The little extra money for "non-ironing" or "wrinkle free" shirts is worth to save the pain. I do not want to iron my clothes anymore, done that more than enough in the military. I make sure clothes are removed from the dryer and hunged right away and this helps greatly.
    Pauly wrote: »
    Spray bottle
    Spray.
    Enjoy
    Pauly
    Humm, tried using the softener either during wash rince and also tried in the dryer and I think both methods are insatisfactory. Do you think this way would work better? I guess I'll try this, out of dryer, hang close and spray with this. Hope it is more efficient. I was thinking of buying a steamer but maybe this will be less time consuming and just as efficient?
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • kevhed72
    kevhed72 Posts: 5,166
    edited August 2009
    I have the same problem with pants....so I drive to work without pants.
    Is it wrong???
  • concealer404
    edited August 2009
    kevhed72 wrote: »
    Is it wrong???
    It's SO right.
  • shack
    shack Posts: 11,154
    edited August 2009
    Wear it wrinkled. I see guys in their perfectly ironed shirts and KNOW they have them delivered to their office from the laundry and probably change them 2 or 3 times a day. I'm not sure who they are trying to impress...but it isn't me. I would rather see someone in a slightly wrinkled shirt who spends his time working rather than worrying how he looks. On the other hand, someone that comes into my office or to a meeting in a shirt that looks like he slept in it for a week tells me something totally different.
    However, in my business, I really don't care what they look like...just what their financial statement looks like.
  • Willow
    edited August 2009
    TECHNOKID wrote: »
    Cheers!
    TK
    No starch using here. I don't dry them in the dryer, hang dry, then iron. I bought a clothes steamer which works great to get wrinkles out in between washes/irons. The lap belt does nothing it's the shoulderstrap that creates folds in the shirt. If they make fitted/tailored wrinkle free shirts I'll try one but till then.
  • TECHNOKID
    edited August 2009
    Willow wrote: »
    I think your best bet is to wear a T shirt or some other slack sport wear while travelling and simply put the shirt on when entering the work place (many federal employees do so in Ottawa with great success). In my situation, I don't have the choice to wear while travelling since I often have to meet with client(s) along the way before getting to the office. I always like to keep a back-up shirt and pants at the office also.
    Cheers!
    TK
    DARE TO SOAR:
    nooshinjohn Posts: 26,002
    edited August 2009
    Willow wrote: »
    The easiest solution is also the most obvious.... DON"T WORK!:p
  • hockeyboy
    hockeyboy Posts: 1,428
    edited August 2009
    I travel quite a bit and started buying these shirts after reading a review in the Wall Street Journal. I will never go back- i get in and hang it overnight. Most of the time I still iron but can get away without if needed.
    http://www.josbank.com/IWCatSectionView.process?IWAction=Load&Merchant_Id=1&Section_Id=1434
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2009
    Drive to work in my White tee then put the Polo on after I arrive.
  • Zeros
    Zeros Posts: 940
    edited August 2009
    Or don't wear a seat belt. Not that I'd recommend that. If you died though, at least your shirt wouldn't be wrinkled. Blood-soaked possibly, but not wrinkled.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2009
    I have to wear a shirt/tie/dress slacks on a daily basis, and I just bring everything in on a hanger and change in the restroom stall before I go into the office (wear shorts/t-shirt for the drive!). I drive 65 miles one way (1.5 hrs) so I would be EXCEPTIONALLY wrinkly... :-)
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Face
    Face Posts: 14,340
    edited August 2009
    Drive to work in your undershirt...it's free.
  • Willow
    edited August 2009
    hockeyboy wrote: »
    I'll check these out for sure. Thanks
    It's not an issue during the winter as my coat covers and shirt doesn't wrinkle it's just spring summer and fall, when I don't wear a coat. Looks like just going in my Tshirt is the best bet for now. I always wear one under my shirts anyway.
  • bruss
    bruss Posts: 1,039
    edited August 2009
    get a motorcycle
  • Willow
    edited August 2009
    23yrs to go
  • devani
    devani Posts: 1,497
    edited August 2009
    I wear wrinkle free shirts from Brooks Brothers...yes they cost around $50 each...I think it's worth it....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • zingo
    zingo Posts: 11,258
    edited August 2009
    I was going to recommend the jacket as it covers up pretty much anything, but not putting on the shirt until you step out of the car works as well.
  • Willow
    edited August 2009
    zingo wrote: »
    The only issue with a jacket is that if it's nice out I'll be too warm and want the AC on abd my wife will find it too cold...
  • Willow
    edited August 2009
    devani wrote: »
    50 is not expensive for a shirt at all, at least I don't think. they might be another option. Guess I 'll have to look around. I don't want to look 30yrs older either
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2009
    I dont really worry about it, if someone else does and cares to comment about it I generally ask them how they think it would look wrapped around their neck??? Of course I smile the whole time and add that Tubes Rule along with a suggestion about where they might put one.
    Of course I suspect my solution is very inappropriate in your particular case.
    RT1
  • brettw22
    brettw22 Posts: 7,623
    edited August 2009
    My tricks name is Tyler.......but I'm not gonna share.......
  • fossy
    fossy Posts: 1,378
    edited August 2009
    I get Tyler to press my cotton also ..... he' old news honey
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2009
    Just spill your coffee in your lap, they won't even notice your shirt.
