What is your trick
Willow
I need to know what you guys do, if anything. I'm tired of getting to work with a wrinkled shirt due to the seatbelt. No I won't buy the wrinkle free shirts either.
Post edited by Willow on
Spray bottle
Half Fabric Softener / Half water. Mix
Spray.
Enjoy
PaulyLife without music would♭ -
THey also sell a spray that is most likely what Pauly just described, but marketed better.
http://www.downy.com/en_US/products/wrinklereleaser.jspIf you will it, dude, it is no dream. -
I drive to work without a shirt, and put it on in the parking lot.
If i'm feeling REALLY ambitious and want to walk in like the perfect employee, i'll shave using my side mirror.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I would hate a job that required shirts and shoes, that is why I became a porno star.
bobman1235 wrote: »THey also sell a spray that is most likely what Pauly just described, but marketed better.
Mine is more cost effective
Therefore no flimflam
If I ironed the shirt and it gets wrinkled because of the seatbelt, who cares. The only way I know to fully prevent it is if you have your shirts dry cleaned and get them starched. It doesn't have to be heavy starch either, light to medium works just fine.
You might not think about it, but the back of your shirt is probably severely wrinkled as well from sitting in the seat!!! Ultimate solution, ride a bike to work.
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
Pauly
I'll check it out, thanks. Or I'll just put my shirt on when I get to work. -
Hummm, shirt wrinkled due to seat belt? Never really had that problem (the back of the shirt sure...). You must be using starch, are you (that I can see)? The little extra money for "non-ironing" or "wrinkle free" shirts is worth to save the pain. I do not want to iron my clothes anymore, done that more than enough in the military. I make sure clothes are removed from the dryer and hunged right away and this helps greatly.I need to know what you guys do, if anything. I'm tired of getting to work with a wrinkled shirt due to the seatbelt. No I won't buy the wrinkle free shirts either.
Humm, tried using the softener either during wash rince and also tried in the dryer and I think both methods are insatisfactory. Do you think this way would work better? I guess I'll try this, out of dryer, hang close and spray with this. Hope it is more efficient. I was thinking of buying a steamer but maybe this will be less time consuming and just as efficient?Spray bottle
Spray.
Enjoy
Pauly
Cheers!
TKDARE TO SOAR:
concealer404 wrote: »I drive to work without a shirt, and put it on in the parking lot.
I have the same problem with pants....so I drive to work without pants.
Is it wrong??? -
Is it wrong???
It's SO right.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Wear it wrinkled. I see guys in their perfectly ironed shirts and KNOW they have them delivered to their office from the laundry and probably change them 2 or 3 times a day. I'm not sure who they are trying to impress...but it isn't me. I would rather see someone in a slightly wrinkled shirt who spends his time working rather than worrying how he looks. On the other hand, someone that comes into my office or to a meeting in a shirt that looks like he slept in it for a week tells me something totally different.
However, in my business, I really don't care what they look like...just what their financial statement looks like."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Cheers!
TK
No starch using here. I don't dry them in the dryer, hang dry, then iron. I bought a clothes steamer which works great to get wrinkles out in between washes/irons. The lap belt does nothing it's the shoulderstrap that creates folds in the shirt. If they make fitted/tailored wrinkle free shirts I'll try one but till then. -
I think your best bet is to wear a T shirt or some other slack sport wear while travelling and simply put the shirt on when entering the work place (many federal employees do so in Ottawa with great success). In my situation, I don't have the choice to wear while travelling since I often have to meet with client(s) along the way before getting to the office. I always like to keep a back-up shirt and pants at the office also.No starch using here. I don't dry them in the dryer, hang dry, then iron. I bought a clothes steamer which works great to get wrinkles out in between washes/irons. The lap belt does nothing it's the shoulderstrap that creates folds in the shirt. If they make fitted/tailored wrinkle free shirts I'll try one but till then.
Cheers!
TKDARE TO SOAR:
The easiest solution is also the most obvious.... DON"T WORK!:pI need to know what you guys do, if anything. I'm tired of getting to work with a wrinkled shirt due to the seatbelt. No I won't buy the wrinkle free shirts either.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I travel quite a bit and started buying these shirts after reading a review in the Wall Street Journal. I will never go back- i get in and hang it overnight. Most of the time I still iron but can get away without if needed.
http://www.josbank.com/IWCatSectionView.process?IWAction=Load&Merchant_Id=1&Section_Id=1434My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Drive to work in my White tee then put the Polo on after I arrive.Shoot the jumper.....................BALLIN.............!!!!!
nooshinjohn wrote: »The easiest solution is also the most obvious.... DON"T WORK!:p
Or don't wear a seat belt. Not that I'd recommend that. If you died though, at least your shirt wouldn't be wrinkled. Blood-soaked possibly, but not wrinkled. -
I have to wear a shirt/tie/dress slacks on a daily basis, and I just bring everything in on a hanger and change in the restroom stall before I go into the office (wear shorts/t-shirt for the drive!). I drive 65 miles one way (1.5 hrs) so I would be EXCEPTIONALLY wrinkly... :-)TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Drive to work in your undershirt...it's free."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I'll check these out for sure. Thanks
It's not an issue during the winter as my coat covers and shirt doesn't wrinkle it's just spring summer and fall, when I don't wear a coat. Looks like just going in my Tshirt is the best bet for now. I always wear one under my shirts anyway. -
get a motorcycle
23yrs to go -
I wear wrinkle free shirts from Brooks Brothers...yes they cost around $50 each...I think it's worth it....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
I was going to recommend the jacket as it covers up pretty much anything, but not putting on the shirt until you step out of the car works as well.
The only issue with a jacket is that if it's nice out I'll be too warm and want the AC on abd my wife will find it too cold... -
50 is not expensive for a shirt at all, at least I don't think. they might be another option. Guess I 'll have to look around. I don't want to look 30yrs older either -
I dont really worry about it, if someone else does and cares to comment about it I generally ask them how they think it would look wrapped around their neck??? Of course I smile the whole time and add that Tubes Rule along with a suggestion about where they might put one.
Of course I suspect my solution is very inappropriate in your particular case.
RT1 -
My tricks name is Tyler.......but I'm not gonna share.......comment comment comment comment. bitchy.
I get Tyler to press my cotton also ..... he' old news honey
Just spill your coffee in your lap, they won't even notice your shirt.>
