phone pre/cartridge recommendations
nooshinjohn
nooshinjohn Posts: 25,931
edited September 2009 in 2 Channel Audio
I am wanting to add a decent phone preamp and new cartridge to my Yamaha PX-3 turntable. I am liking the Denon DL-160, and have no clue on preamps... any advise from the vinyl guys will be very helpful.:)
Post edited by nooshinjohn on
  • thsmith
    thsmith Posts: 6,082
    edited August 2009
    I have a Cambridge Audio 640P and have listened to a Parasound Zphono. Both are good choices.
    I also use the Denon DL-160, excellent cart for the money.
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2009
    For phone, I'd recommend AT&T.
    SOPA
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited August 2009
    I would recommend Verizon.;):D
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • thsmith
    edited August 2009
    I prefer Vontage
  • schwarcw
    schwarcw Posts: 7,358
    edited August 2009
    If you go with the Denon DL-160, make sure that your phono pre as a gain of at least 45 dB. The Denon is a high output MC (1.6 V) but does not have the high output of say a AT 440 MLa which is closer to 5.0 V.
    Carl
    mhardy6647 Posts: 35,045
    edited August 2009
    I like the Bottlehead Seduction very much for a phono preamp at a good price, but:
    1) Ya gotta sling solder
    2) Gain is a little low for a typical HOMC like the DL-160
    http://www.bottlehead.com/store.php?crn=220&rn=429&action=show_detail
  • polkatese
    polkatese Posts: 6,767
    schwarcw wrote: »
    Hey Carl,
    need to pick your brain on your recommendation: I am thinking of getting DL-160 to be paired with SL1200MKII, what would you recommend for Phono Preamp on this combo?
    TIA
    f
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • schwarcw
    Hi Frances!
    Get yourself a phono pre with more than 44 dB gain. My Hagerman sounds fantastic and it has 44 dB gain. However, when I put in a step up transformer, it really came alive! I say get something with more than 55 dB gain with the DL-160. Your budget obviously has a lot to do with what you buy. The DL-160 sounds great! Other cartridges to consider are the Shure M97XE or the AT 440MLa are very good cartridges for not a whole lot of scratch that you can use without a high gain preamp.
    PM me if you want, we can chat off line.
    Carl
  • polkatese
    Thanks Carl! I am waiting for Doug (dkg999) Pro-Ject tube box II, which according to its spec has 60 dB gain for MC, which DL-160 is. I'll ping you if all goes as plan.
    Thanks again.
  • schwarcw
    That phono pre will do the trick! Very nice phono pre, and of course Doug is a great guy!
    Carl
    SCompRacer Posts: 9,112
    The 440 MLa is a great cartridge, and has 4.0mV output. It works well with the Coronet 2 and both Project phono stages (the II and II SE). I had all three of them here the other day. The DL-160 will be fine with 60dB of gain.
  • ben62670
    ben62670 Posts: 15,969
    Carl or Richie I have an Ortofon om5e in my Project TT. I don't really like anything about it except the looks. The Denon, and the AT440 are almost $200. Do you think the sure 97 performs almost as good as the Denon, or the 440? The sure is only $90.
    Thanks again
    Ben
    Ben
  • polkatese
    SCompRacer wrote: »
    Thanks Rich!
  • fbm211
    fbm211 Posts: 1,488
    Try LP gear Ben.They have the best prices Ive seen on carts.(Shipping is a little high though.)
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • ben62670
    Thanks for the link. What I really should do is try and borrow one from a local Polkie. The Ortofon that came with it has decent sound stage, but is just too sterile sounding.
    Ben
    LP Gear is great to deal with and where I got my AT 440MLa. Tonight, Amazon is cheaper on the 440MLa by $5 ($120), and show the Shure M97XE for $62. (The high accuracy M97XE is $90).
    Some folks say the 440MLa is bright but I don’t agree. Even when playing on some neutral, revealing ESL speakers. I prefer the 440MLa over the Shure M97XE, but $62 is an excellent price for a good cartridge. As always, much depends on the gear and your listening tatse.
    I had an Ortofon OM5E. If it wan’t so expensive, you can upgrade the 5E with an OM20 sytlus. But if you don't like the sound now, you should try a different brand. I ended up with an OM20 cartridge buying a used table and it sounded nice. IIRC, Noel has the Denon cartridge w/OM20 now.
  • schwarcw
    Ben, I thought the Shure sounded pretty good, especially for the money. It had a nice high ouput with a full sound. Not thin or bright. I agree with Rich I have never thought the 440 ML was bright. I got a lot of good, tight bass with the 440 ML. No problems with the Shure for SURE!:D
    Carl
  • ben62670
    HeHe. I need to see if George has a few carts I can play with. Bill is real cool too, and not to far. For $62 I could probably get at least $30 for my Ortofon on the bay. How can you tell the difference between the two sure's? They both have the same model number.
    Ben
  • Paden501
    Paden501 Posts: 286
    I like my Shure M97xe. For that price, it's a no brainer. I also looked at the 440MLa, but all the reviews on the Shure swayed me, and I don't regret it.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
  • ben62670
    I think I will go with the Shure. I know the AT sound, and liked it, but if I can barrow a few cartridges then I could do a little review on the results. We are getting together again here in GA in a few weeks. Maybe I can get a few guys to bring over some cartridges. My tables is a Project (cheaper model) and I think a review of the Shure, Denon, and the AT440 would be an awesome thing to have here. This question comes up a lot. Not as bad as how many watts do I need, but I know I have asked it more than once:o
    Ben
  • jimmydep
    jimmydep Posts: 1,305
    I bought the Shure M97xE a few months ago from Amazon for about $65, I'm still in the break-in period but it sounds as good if not better than my old Stanton 681eee cart.
    Note: If you do get the Shure, look under all the foam packing, you'll find a cardboard protractor there, they make no mention of this in the instructions.
    http://www.amazon.com/Shure-M97xE-High-Performance-Magnetic-Cartridge/dp/B00006I5SB/ref=sr_1_1?ie=UTF8&s=electronics&qid=1253105482&sr=8-1
    Jimmy
  • SolidSqual
    SolidSqual Posts: 5,218
    I like the Jolida JD-9A. It's awesome. But, I am looking to buy the Musical Surroundings Nova Phonomena.
  • thsmith
    polkatese wrote: »
    Thanks again.
    I have a Denon 160 and it is a MC (HO) but I am using my Cambridge Audio 640P set as a MM, I was told that MM is what I should set the Phono Pre for a HOMC, Should I change the setting to MC ?
  • ozzy21236
    ozzy21236 Posts: 100
    thsmith wrote: »
    HOMC should be used with MM section of the Cambridge 640p so it is not necessary to switch.
    Technics SL1210mkll / AT125LC / Cambridge Audio 640P / Yamaha TX-950 / Onkyo TA-2600 / Yamaha C-80 pre/Adcom GFA 545 / Polk Audio Monitor 12 Series 2
  • thsmith
    ozzy21236 wrote: »
    Thanks Ozzy, that is what I thought. The comment above confused me.
  • Dawgfish
    Dawgfish Posts: 2,554
    ben62670 wrote: »
    Keep me posted in that Ben. Of course you know how my work schedule is, so I can't make any guarantees I'll make it. I have a Denon DL-160 and Shure M97xe I could bring for us to test. I think you'll like the Shure, it really is a great cartridge for the money. It sounds a little flat and dry at first, but opens up nicely as the stylus breaks in and becomes much more musical. Give it some time before you make judgement on it. I was ready to get rid of mine the first month or so until it broke in. It sounds like a totally different cartridge now. The DL-160 is just a pleasure all together. It sounded great out of the box and just continues to sound better and better. Hopefully we can get together in a few weeks so you can see for yourself.
    Steve
