Cross over settings
ls7z06
ls7z06 Posts: 95
I have an Onkyo TX SR-806 with all Polk speakers.. RTiA7 fronts, CSiA6 center, FXiA6 surrounds and DSW pro 500 sub. I have the cross over set at 80Hz for all. I can't tell a lot of difference regardless of setting. Does 80Hz sound right for my set up?
Post edited by ls7z06 on
  • kuntasensei
    kuntasensei Posts: 3,263
    edited August 2009
    80Hz is usually right for just about every setup.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • danz1906
    danz1906 Posts: 5,144
    edited August 2009
    ls7z06 wrote: »
    Yep, 80Hz works great with Movies.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • kuntasensei
    edited August 2009
    If you want a more specific answer, typically you want to set the crossover at least a half-octave above the speaker's -3dB point to ensure that the speaker has time to transition to the subwoofer. You could get away with setting your RTiA7s down to 60Hz, but at the expense of headroom from your 806 (because reproducing deeper bass at the speaker requires more power from the receiver). Crossing them at 80Hz shares the load between the receiver and the subwoofer's amp nicely, so I'd stick with that if you're primarily doing movie watching.
    Equipment list:
    Emotiva XPA-3 amp
  • McLoki
    McLoki Posts: 5,231
    edited August 2009
    The only deviation from that would be the LFE channel and that should be set to at least 120hz (or higher) if at all possible. Some AVR's do not have settings for LFE and in that case - stick with the 80hz all the way around - but I am pretty sure your Onk does have it.
    Another benefit of letting your sub take care of the bass (below 80hz) even if your speakers can play lower is that typically your sub is set in a place that has the best bass sound. That may not be true with your other speakers as they are more placed for best full range sound (and often where they look the best).
  • ls7z06
    ls7z06 Posts: 95
    edited August 2009
    Got it. All set to 80Hz except LFE which is now set to 120Hz. Thanks much.
