Should I purchase these tubes.......
heiney9
heiney9 Posts: 25,492
edited August 2009 in 2 Channel Audio
......50's NOS Raytheon Black Plate Triple Mica for $60. It's an odd tube designation that is a variant of the 12AT7 my Dared uses.
It seems I read the Raytheon Black Plates are supposed to sound wonderful. I'm doing a LOT of tube buying/rolling and this is towards the upper end of $$$ strictly for comparing/contrasting tubes for this pre.
P.s. Let me know your thoughts.
Post edited by heiney9 on
    edited August 2009
    Probably just found my answer here as these are the exact tubes I'm looking at.
    A great dual triode much like the 7062 above, but with USA blackplate military specs. 1950s vintage with triple mica and a sweetness you have to hear to believe. These are the low noise audio screened, 10,000hr. rated heater life tubes. You may never go back to a 12AT7 once you hear these.
  • george daniel
    george daniel Posts: 12,096
    edited August 2009
    My tube experience with the Raytheon's is limited to the 6sn7 and some other 9 pin versions,all of which have been positive,,it's a tube that grew on me,, subtle at first,,and as I heard others,, the differences were more apparent. Good luck.
    edited August 2009
    Yeah, I hear ya George. Experimentation is the key. Just don;t want to overpay for a less popular tube designation if I need to flip them eventually.
    So far this is I've used in place of 12AT7's
    RFT ECC81 (nice soundstage, not very forgiving and super linear midrange)
    RCA 6211 (blk plate) sweet, open
    RCA 6201 (blk plate) sweet, open
    GE JAN 5965 (gray plate) a tad dry
    On the way
    CBS Hytron 7728 Gold Pins
    1950 RCA black plate 5V4G rectifier.
    Looking at getting
    GE 6211 clear top double side getter gray plate
    RCA 6201WA black plates
    GE 6979 gray plates
    Mullard ECC81
    Telefunken ECC801S (if they don;t go to high) very rare and desirable
  • W WALDECKER
    W WALDECKER Posts: 900
    edited August 2009
    Hey H9, NOS Siemans 12AT7 , Valvo 6201 and Sylvania Gold brand 6201 are 12AT7 varients that also have a following.Good Luck....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
