Listening volume levels
Klipsch_Fan
Klipsch_Fan Posts: 26
edited August 2009 in 2 Channel Audio
Just curious what db level's people listen to their music. Also, just measuring sound levels A-weighted (500hz to 10,000hz). Bass is good at times, but I'm more interested in mid-bass and up.
Me, I like 95 to 105db. :D
Fred
_______________________
Klipsch "A Legend in Sound" :)
Post edited by Klipsch_Fan on
  • McLoki
    McLoki Posts: 5,231
    edited August 2009
    you are a fan of the right speakers for that.... I am usually more in the 80-90db range.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited August 2009
    I've never actually measured but I am sure I would be well under 90 db
    Regards,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    Toolfan66 Posts: 18,148
    edited August 2009
    It depends on what i am listening to, yesterday was the first time i pushed my 1.2tl's to to 12 O clock, I had WAR's lowrider on, This was on vinyl as well.
    I put Diana Krall on (CD) and 10 O clock was just fine. I love her work but after awhile I find myself nodding off.
    I will pull out my SPL and see what db's I come up with.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2009
    If I pop in a concert dvd I am around 90-95 dB.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • Phil Dawson
    Phil Dawson Posts: 288
    edited August 2009
    GENERALLY music is mixed at approximately 85dB. If you listen at a higher level you will hear more bass and at a lower level you will hear less bass (thus the reason for the "loudness" switches I used to see on receivers. This is only a general guideline and of course there are many recordings mixed at higher and lower levels. 85db can be too loud for some situations and too soft for others but it is a good place to start if you want to hear what the recording is "supposed" to or was intended to sound like.
    Phil
    SRS-SDA Front
    2 cs400i Center
    SRS-SDA Rear
    Shure 12in sub
    B&K ref 10 pre-pro upgr to ref 50
    Techniques 1200 TT
    Mac MR71 Tuna
    Lexicon rt-20 uni player
    HK citation pre for TT
    2 PSE Studio Mono Blocks
    4 PSE Studio Stereo Amps
    1 Mac 2100 Amp for sub
  • thuffman03
    thuffman03 Posts: 1,325
    edited August 2009
    It all depends on how I feel, what I want to listen too and what time of day.
    I have no idea what the db level I am putting out but I can tell how many wpc I am putting out. Most of the time I am between 3 and 10 wpc. When I am rocking the house it will be 200+ wpc. When I am at that level it is really loud.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • lightman1
    lightman1 Posts: 10,797
    edited August 2009
    Phil...Spot on.....
    Kex....I hope a lot of people read this and reconsider cranking the volume because they can.
    Save the ears, boys and girls.
    treitz3 Posts: 20,069
    edited August 2009
    I listen as close to the perfect volume with everything. Reference is being able to recreate what your system is capable of to the most realistic realm possible. Nothing more, nothing less.
    When you are absorbed in the music and you feel nothing but the music?
    Yeah, you got it.
    edited August 2009
    Just one more thing. I let my ears decide.
  • lightman1
    edited August 2009
    Kex wrote: »
    Yup, that's pretty much it for me! I use reference level as a rough guide, to avoid playing too loud inadvertently, but the reason I want to play that loud in the first place is because of the realism it seems to recreate. Listening to a piano as though the piano were 100' away or in the next room? Why bother?!
    Eight rows back, a little to my right, acompany(?) low and center......
  • John K.
    John K. Posts: 822
    edited August 2009
    Fred, you might reconsider that grin after your 95-105dB statement, because if you meant that literally, you're in danger of suffering permanent hearing damage. Those levels are okay for split-second peaks but are far too high for use as an average listening level. There are some rather lenient suggestions in the literature for allowable sound level exposure in the workplace, but these allow for some long-term hearing loss which is considered acceptable(by some)in a work environment. No such loss should be acceptable in a home listening environment and the allowances set by the EPA and World Health Organization for such situations is significantly lower, as illustrated in these tables .
    For my own use, when listening "loud" the average level would be on the order of 80-85dB, with very brief peaks on the most dynamic classical material(much almost uniformly very loud pop material has a dynamic range approaching zero)being as much as 20dB above that. More typical listening for enjoying music might be 10dB or so below that, and for listening at background levels at least another 10dB reduction would be applied.
    We should be in high fidelity audio to increase our enjoyment of music, and it's unnecessary to damage our hearing while paying extra for the privilege.
  • mmadden28
    mmadden28 Posts: 4,283
    edited August 2009
    I wonder, are the damaging levels lower for children?
    Pool: Atrium 60's/45's
  • dougy
    dougy Posts: 182
    edited August 2009
    I don't keep my spl meter on all the time, but when I have checked, even when the wife and kids are away and I feel like I'm pretty much much rockin' the house, sound pressure levels are usually peaking in the 95dB range. But usually, I'm down closer to 85dB peaks. I don't want to damage what's left of my hearing ability.
    I once read a that good rule of thumb is to keep the volume down to where you can hear your own normal-level speaking voice over the music. Louder than that is too loud. I don't know how true that really is, but I find myself more or less going by it.
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
