Anyone tried DD-WRT hack to create client bridge access point?
polkatese
I am planning of installing DD-WRT mod to flash a Linksys WRT54G2 so that I can have it sitting in my entertainment center. With more and more gears having RJ-45 connection (i.e. consoles, Processor, Bluray player, DirecTV DVR), I thought it is time to have a client bridge setup close to the center.
Has anyone did one? my only concern is to brick the AP, but hopefully I'll do enough research beforehand as to prevent this.
Any feedback?
Any feedback?
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
I did it, piece of cake.
Yup - it's pretty easy.
I have 6 WRT54G's in a mesh repeater bridge setup.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Cool, I'll ping you guys if I run into problem. My primary is WRT54GS, and WRT54G2 should be here tomorrow.
Thanks.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
That's cool I need to look in to getting a couple of these.Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
Anyone have a link explaining what this is all about? I have a few extra routers, and if it's something cool that i would have a use for, i'd like to make use of them.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
In essence, you are flashing your router to act like a "client bridge", to talk to the primary wireless router (that is connected to the internet through modem, dsl, etc.), and allows you to connect clients (xbox360, DVR, etc.) via wires (RJ45) to this router.
www.dd-wrt.com
http://www.dd-wrt.com/dd-wrtv3/dd-wrt/hardware.htmlI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
concealer404 wrote: »Anyone have a link explaining what this is all about? I have a few extra routers, and if it's something cool that i would have a use for, i'd like to make use of them.
Only certain routers qualify as hackable. They will include Linksys, some Buffalo, some Intel. Basically having a linux kernel.
google dd-wrt and their wiki. -
www.dd-wrt.com
Wouldn't that work with just one router? Unless you have more clients than the router has ports? I'm googling as you read this.Currently looking for speakers(spending 1K)
Onkyo 805 -
Buncha f*kin geeks...
DD-WRT is cool lot's of options
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
unclepauly wrote: »Wouldn't that work with just one router? Unless you have more clients than the router has ports? I'm googling as you read this.
The biggest benefit for me is to be able to have secondary client bridges around the house without having to run RJ-45 wires....I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
It would work, if all your devices were sitting next to your router or you had your entire house hard wired and jacked up to go back to your router/switches.
If you have equipment not sitting next to your router, and you don't want to run wires (lazy, concrete slab, rental, condo, unconnected structure, guest house on your property, etc), that is where people will use a wireless bridge.
W -
ok. Just finished installing the new WRT54G2. Flashed the firmware, it wasn't as clean as I hope for, but at the end, it works. I hooked it up to a DTV DVR HR20-700 to test it out. So far, I am able to activate On-Demand, and queue an HD movie to see how long will it takes to download one.
Question: has anyone hook up their BD players to the internet, to do BD Live interactivity? worth anything?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
