Possible way to add an external Amp
kcoc321
I have been looking the the Velodne MiniVee Subs to add as a Pair to enrich my Bass, and I noticed they have included a Line Output in addition to the Line inputs on their subs.
Has anyone tried this?
Is there any way to change the cross-over point? The manual I read said it was at 80hz..in essense the same as I can assign in my AVR. But then the amp & speaker connected to it would only get >80hz signal.
Post edited by kcoc321 on
That's meant for daisy chaining subs...not hooking up external amps.
In theory I guess it might work...but I wouldn't even bother trying personally.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I'll have to call them about that. IF I daisy-chained a second Sub to the line-out, it looks like it would not get the appropriate signal, since the line-out is being filtered to only put out signal above 80hz, at least the way I read it.
So would you just use a "y-splitter" instead? -
bigger pic from the manual
tried resizing it, but time expired before I could repost it. -
Even if it does output the full spectrum, I would not want to use the A/D converter from a plate amp, it probably wouldn't sound good at all.
Just save up and do it the right way."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
What A/D converter? It's all analog already. They intended it this way so you can use satellite speakers in a sub/sat configuration and the sub would already be crossed over at it's optimum frequency. That would make matching satellites rather hard though.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Yes, you would want a Y-splitter assuming you have a receiver or integrated amp with a bass-management system. The crossover line-in/line-out jacks on the MiniVee's are for using the subs in an environment (typically sub-sat) with a pre-amp / amplifier system that does not have a bass-management capability.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
comfortablycurt wrote: »That's meant for daisy chaining subs...not hooking up external amps.
thanks Curt..So would I use a Y-slitter then?
Dr FaceEven if it does output the full spectrum, I would not want to use the A/D converter from a plate amp, it probably wouldn't sound good at all.
Thanks for your input. Can you enlighten me what you talkin about with the A/D converter? Sorry, I don't understand.
I would be "branching fron the 2-channel outputs from my Preamp, that does not have Sub outputs, and only one set of outputs (B&K PT3)
What would be the "right way" to do it? Looking for Full Range connections to the Sub and the Amp & other speakers.
ThanksYes, you would want a Y-splitter assuming you have a receiver or integrated amp with a bass-management system. The crossover line-in/line-out jacks on the MiniVee's are for using the subs in an environment (typically sub-sat) with a pre-amp / amplifier system that does not have a bass-management capability.
Thanks Marty, I am hoping that is a way to have the bypass loop Full Range if I can [IF I can keep this Preamp and don't have to junk it and get a different one] Do I need a AQ or eq "Y" or is the std Rat-shack gold ones okay?
Do I loose signal strength using a "Y" as opposed to looping thru the sub?
Or is there some kindof "Distribution hub" that would be better?
Thanks everyone. -
I shouldn't post before my AM coffee... Not a A/D converter, I meant speaker level to line level circuit.
I would look into a receiver with preamp outputs and an adjustable subwoofer crossover frequency. HK will probably be cheapest to have all these features and make good receivers. From there I would recommend Onkyo."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
kcoc3210,,
You mentioned that the PT3 had no sub outputs. I thought the PT3 had Mono/Sub outputs in addition to both High Pass outputs and Full Range output. Am I missing something or just not remembering the PT3 correctly?Sony 60'' SXRD 1080p
No, Marty you are complete correct. Thanks for your input.
My PT3 does have a (1) FUll Preout, sub out (x'd at 80hz I think) a mono out (L/R together) and a High range Preout.
That is why I was alittle confused with the suggestion to buy a HK AVR...lol....sorry, that's not going to happen...At least for me.
Besides I also already have a B&K 101 that does have (2) sub preouts, so I could always try that..although the x-over pt is not changable on the earlier AVR's.
Back to 2.1: However...I was thinking about how to try and run 2 subs Full Range AND run my Fronts Full Range. Maybe it is mute, but I have been reading ppl saying they like it that way especially for music...
Besides with the "possible" daisy chaining with the MiniVee, I could Bi-amp Full Range as well....oh well...
Guess I'll just be stuck with one amp Full range.....and just "y" the sub out.
Till I find a 'high audio' 1 to 4 splitter...hehe.
Or a reasonably priced, warm sounding Pream with MORE preouts.
Thanks everyone.:D
