Possible way to add an external Amp
edited August 2009 in Electronics
I have been looking the the Velodne MiniVee Subs to add as a Pair to enrich my Bass, and I noticed they have included a Line Output in addition to the Line inputs on their subs.
Has anyone tried this?
Is there any way to change the cross-over point? The manual I read said it was at 80hz..in essense the same as I can assign in my AVR. But then the amp & speaker connected to it would only get >80hz signal.
Post edited by kcoc321 on
Welcome!
    edited August 2009
    That's meant for daisy chaining subs...not hooking up external amps.
    In theory I guess it might work...but I wouldn't even bother trying personally.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited August 2009
    I'll have to call them about that. IF I daisy-chained a second Sub to the line-out, it looks like it would not get the appropriate signal, since the line-out is being filtered to only put out signal above 80hz, at least the way I read it.
    So would you just use a "y-splitter" instead?
    edited August 2009
    bigger pic from the manual
    tried resizing it, but time expired before I could repost it.
    edited August 2009
    Even if it does output the full spectrum, I would not want to use the A/D converter from a plate amp, it probably wouldn't sound good at all.
    Just save up and do it the right way.
    edited August 2009
    Face wrote: »
    What A/D converter? It's all analog already. They intended it this way so you can use satellite speakers in a sub/sat configuration and the sub would already be crossed over at it's optimum frequency. That would make matching satellites rather hard though.
    Main Surround -
    edited August 2009
    kcoc321 wrote: »
    Yes, you would want a Y-splitter assuming you have a receiver or integrated amp with a bass-management system. The crossover line-in/line-out jacks on the MiniVee's are for using the subs in an environment (typically sub-sat) with a pre-amp / amplifier system that does not have a bass-management capability.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
    edited August 2009
    thanks Curt..So would I use a Y-slitter then?
    Face wrote: »
    Dr Face :) Thanks for your input. Can you enlighten me what you talkin about with the A/D converter? Sorry, I don't understand.
    I would be "branching fron the 2-channel outputs from my Preamp, that does not have Sub outputs, and only one set of outputs (B&K PT3)
    What would be the "right way" to do it? Looking for Full Range connections to the Sub and the Amp & other speakers.
    Marty913 wrote: »
    Thanks Marty, I am hoping that is a way to have the bypass loop Full Range if I can [IF I can keep this Preamp and don't have to junk it and get a different one] Do I need a AQ or eq "Y" or is the std Rat-shack gold ones okay?
    Do I loose signal strength using a "Y" as opposed to looping thru the sub?
    Or is there some kindof "Distribution hub" that would be better?
    Thanks everyone.
    edited August 2009
    I shouldn't post before my AM coffee... Not a A/D converter, I meant speaker level to line level circuit.
    I would look into a receiver with preamp outputs and an adjustable subwoofer crossover frequency. HK will probably be cheapest to have all these features and make good receivers. From there I would recommend Onkyo.
    edited August 2009
    kcoc3210,,
    You mentioned that the PT3 had no sub outputs. I thought the PT3 had Mono/Sub outputs in addition to both High Pass outputs and Full Range output. Am I missing something or just not remembering the PT3 correctly?
    TT = Audio Technica
    edited August 2009
    No, Marty you are complete correct. Thanks for your input.
    My PT3 does have a (1) FUll Preout, sub out (x'd at 80hz I think) a mono out (L/R together) and a High range Preout.
    That is why I was alittle confused with the suggestion to buy a HK AVR...lol....sorry, that's not going to happen...At least for me.
    Besides I also already have a B&K 101 that does have (2) sub preouts, so I could always try that..although the x-over pt is not changable on the earlier AVR's.
    Back to 2.1: However...I was thinking about how to try and run 2 subs Full Range AND run my Fronts Full Range. Maybe it is mute, but I have been reading ppl saying they like it that way especially for music...
    Besides with the "possible" daisy chaining with the MiniVee, I could Bi-amp Full Range as well....oh well...
    Guess I'll just be stuck with one amp Full range.....and just "y" the sub out.
    Till I find a 'high audio' 1 to 4 splitter...hehe.
    Or a reasonably priced, warm sounding Pream with MORE preouts.
    Thanks everyone.:D
Welcome!
Welcome!
