bi-wire
dholmes
Why cant you use another run of good spk wire for bi-wiring instead of the monster z2b? It seems to me that it would do the same as the z2b!thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
There is nothing that says you can't. Go ahead and try it, see what you think. Some makers tailor their wires and technology for the high and low frequences, but I don't think Monster is one of them.Political Correctness'.........defined
President of Club Polk -
It is a little cleaner of an install perhaps, but that's subjective. Monster Cable does have the runs split into high/low format.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
their is no difference in the actual high and low wire from monster, simply marked for install purposes.. cleaner looks maybe, but i used 2 runs of wire for a year before moving to bulk monster 14-4 bi-wire.. it does look better, specially with the monster lock banana's...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
FWIW, I've read that it's preferable to run the same wire to both sets of posts in a bi-hhhwire configuration.
About 3 hours prior to the flowing of the hhhwine.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
