bi-wire
dholmes
dholmes Posts: 1,136
Why cant you use another run of good spk wire for bi-wiring instead of the monster z2b? It seems to me that it would do the same as the z2b!thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
    F1nut Posts: 51,699
    edited August 2003
    There is nothing that says you can't. Go ahead and try it, see what you think. Some makers tailor their wires and technology for the high and low frequences, but I don't think Monster is one of them.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2003
    It is a little cleaner of an install perhaps, but that's subjective. Monster Cable does have the runs split into high/low format.
  • faster100
    faster100 Posts: 6,124
    edited August 2003
    their is no difference in the actual high and low wire from monster, simply marked for install purposes.. cleaner looks maybe, but i used 2 runs of wire for a year before moving to bulk monster 14-4 bi-wire.. it does look better, specially with the monster lock banana's...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited August 2003
    FWIW, I've read that it's preferable to run the same wire to both sets of posts in a bi-hhhwire configuration.
    About 3 hours prior to the flowing of the hhhwine.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
