External Amp Question
uncmike
Just getting into external amps and have an opportunity to buy a Marantz MM-9000 5 channel power amplifier (specs state 150X5) for $250.
Is this a good deal? Will it work well with my set up:
Denon 4306
Rti-a7 rears
csi a6
rti a9 mains
I want it to power the speakers sufficiently and am willing to wait/pay a little more if another amp will work better. Didn't know if 150 wpc would make that big of a sound difference since the denon is rated 130 wpc.
Thanks for the help and sorry if this is a noop question.
Denon 4306
Rti-a7 rears
csi a6
rti a9 mains
Fronts L/R: Polk Rti-a9
Center: Polk CSi-a6
Surrounds L/R: Polk Rti-a7
Subs: Velodyne DPS12
Receiver: Denon AVR 4306
Source: HTPC tower/360 elite
Panamax Power Conditioner
AudioQuest Type 4 Cables
Center: Polk CSi-a6
Post edited by uncmike on
That's a good price if it's in good condition. I use one to power my center, surrounds and zone 2. Never tried it on my mains,so no real comments there.
I would consider that a great deal. It will make a difference. Your Denon is rated at 130wpc, but i'd be surprised if it put that out without clipping. This will be cleaner power.
So this will power everything or would I be better of with a used adcom 2 or 3 channel putting out about 200 wpc to just the mains and having the denon power the rest?Fronts L/R: Polk Rti-a9
Center: Polk CSi-a6
AudioQuest Type 4 Cables -
That's a tough call. I think I would prefer the above option.
But it might come down to your room as to what would be better. Not knowing what used 2/3 ch Adcoms are going for the $250 price on the Marantz could be very tempting -
Price for the adcom would be about the same, maybe $50-$60 more. I just didn't want to get the marantz and then find out that I would have been better off just giving the rti a9s more power.
It sounds like I'm getting confirmation that $250 is a good deal though and I'm leaning towards that.
Thanks for the quick replys, any other thoughts/suggestions?Fronts L/R: Polk Rti-a9
Center: Polk CSi-a6
uncmike, I feel the Marantz is definitely worth purchasing.
I think you will also notice a greater improvement in overall sound quality than you may have first thought,or realized.
And for what it is worth to you, I really like your Polk Audio speaker setup.
Take Care Of Yourself And Happy Listening.
B.B.3Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's -
Those Marantz are good amps and should give better sound than the Denon. But everyone's ears are different.
Let me through another question out there about bi-amping if I can:
So to hook up the speakers I would run all of the cables from the top speaker posts to the external amp, and all of the cables from the bottom speaker posts to the 4306 receiver?
I would also use the denon's pre-outs to connect the speakers from the external amp to the 4306. So I would need 9 speaker cables (like aq type 4) and 5 interconnect cables, correct?
Is my understanding correct?Fronts L/R: Polk Rti-a9
Center: Polk CSi-a6
