External Amp Question
uncmike
uncmike Posts: 29
edited July 2009 in Electronics
Just getting into external amps and have an opportunity to buy a Marantz MM-9000 5 channel power amplifier (specs state 150X5) for $250.
Is this a good deal? Will it work well with my set up:
Denon 4306
Rti-a7 rears
csi a6
rti a9 mains
I want it to power the speakers sufficiently and am willing to wait/pay a little more if another amp will work better. Didn't know if 150 wpc would make that big of a sound difference since the denon is rated 130 wpc.
Thanks for the help and sorry if this is a noop question.
Fronts L/R: Polk Rti-a9
Center: Polk CSi-a6
Surrounds L/R: Polk Rti-a7
Subs: Velodyne DPS12
Receiver: Denon AVR 4306
Source: HTPC tower/360 elite
Panamax Power Conditioner
AudioQuest Type 4 Cables
Post edited by uncmike on
  • WilliamM2
    WilliamM2 Posts: 4,788
    edited July 2009
    That's a good price if it's in good condition. I use one to power my center, surrounds and zone 2. Never tried it on my mains,so no real comments there.
  • concealer404
    concealer404 Posts: 7,440
    edited July 2009
    I would consider that a great deal. It will make a difference. Your Denon is rated at 130wpc, but i'd be surprised if it put that out without clipping. This will be cleaner power. :)
  • uncmike
    uncmike Posts: 29
    edited July 2009
    So this will power everything or would I be better of with a used adcom 2 or 3 channel putting out about 200 wpc to just the mains and having the denon power the rest?
    Center: Polk CSi-a6
  • apphd
    apphd Posts: 1,514
    edited July 2009
    uncmike wrote: »
    That's a tough call. I think I would prefer the above option.
    But it might come down to your room as to what would be better. Not knowing what used 2/3 ch Adcoms are going for the $250 price on the Marantz could be very tempting
  • uncmike
    uncmike Posts: 29
    edited July 2009
    Price for the adcom would be about the same, maybe $50-$60 more. I just didn't want to get the marantz and then find out that I would have been better off just giving the rti a9s more power.
    It sounds like I'm getting confirmation that $250 is a good deal though and I'm leaning towards that.
    Thanks for the quick replys, any other thoughts/suggestions?
    Center: Polk CSi-a6
  • BB3
    BB3 Posts: 297
    edited July 2009
    uncmike, I feel the Marantz is definitely worth purchasing.
    I think you will also notice a greater improvement in overall sound quality than you may have first thought,or realized.
    And for what it is worth to you, I really like your Polk Audio speaker setup.
    Take Care Of Yourself And Happy Listening.
    B.B.3
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Sonic Frontiers SFCD-1
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    2-Carver Silver 7-T's
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio SDA-SRS 1.2TL
    PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • GEBBY44
    GEBBY44 Posts: 939
    edited July 2009
    Those Marantz are good amps and should give better sound than the Denon. But everyone's ears are different.
  • uncmike
    uncmike Posts: 29
    edited July 2009
    Let me through another question out there about bi-amping if I can:
    So to hook up the speakers I would run all of the cables from the top speaker posts to the external amp, and all of the cables from the bottom speaker posts to the 4306 receiver?
    I would also use the denon's pre-outs to connect the speakers from the external amp to the 4306. So I would need 9 speaker cables (like aq type 4) and 5 interconnect cables, correct?
    Is my understanding correct?
    Center: Polk CSi-a6
