Audio Control LCi8,DQL-8 or Clean Sweep?
JAGUARXKR2005
I am looking for a good piece to us in my 05 Jag XKR Coupe with the factory Alpine 320 Watt system. The System that is in it now is 8 Channels with 2 channels covering the Dash 3.5" and Tweets and 2 Channels covering the door midbass, 2 Channels covering the rear 6.5" and 2 Channels go to the 9" Sub with a Sub Volume Control on the Factory Head Unit.
Can I run my Low Passed leads that go to my factory sub into these because if so I can then still use my Sub Volume Control to power the new amp going to the new sub.
I have been told by a a shop that sells JL Clean Sweeps that there has been alot of noise issues with them.
Post edited by JAGUARXKR2005 on
Yes, the Cleansweep is kinda noisy. Check out the Rockford Fosgate 360.1 and 360.2polkaudio sound quality competitor since 2005
The JL I have used in a accord install it is not bad just a pain to setup, I have not used the mtx bigger ones but I used the MTX RE Q worked pretty good.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Thanks so the Audio Control is out of the question? I did some research on here for the Clean Sweep it it had alot of praise but I am guessing that went away with it being out a bit longer. I really like the function of the Audio Control stuff and you dont need to use a Laptop or PDA to work it like the Fosgate...
Thanks -
out of question? i sure dont think so..Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
