Audio Control LCi8,DQL-8 or Clean Sweep?
JAGUARXKR2005
JAGUARXKR2005 Posts: 10
edited July 2009 in Car Audio & Electronics
I am looking for a good piece to us in my 05 Jag XKR Coupe with the factory Alpine 320 Watt system. The System that is in it now is 8 Channels with 2 channels covering the Dash 3.5" and Tweets and 2 Channels covering the door midbass, 2 Channels covering the rear 6.5" and 2 Channels go to the 9" Sub with a Sub Volume Control on the Factory Head Unit.
Can I run my Low Passed leads that go to my factory sub into these because if so I can then still use my Sub Volume Control to power the new amp going to the new sub.
I have been told by a a shop that sells JL Clean Sweeps that there has been alot of noise issues with them.
Post edited by JAGUARXKR2005 on
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2009
    Yes, the Cleansweep is kinda noisy. Check out the Rockford Fosgate 360.1 and 360.2
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2009
    The JL I have used in a accord install it is not bad just a pain to setup, I have not used the mtx bigger ones but I used the MTX RE Q worked pretty good.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • JAGUARXKR2005
    edited July 2009
    Thanks so the Audio Control is out of the question? I did some research on here for the Clean Sweep it it had alot of praise but I am guessing that went away with it being out a bit longer. I really like the function of the Audio Control stuff and you dont need to use a Laptop or PDA to work it like the Fosgate...
  • cadenceclipse
    cadenceclipse Posts: 459
    edited July 2009
    out of question? i sure dont think so..
    Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
