Speaker level calibration question
silversubaru
silversubaru Posts: 42
edited July 2009 in Electronics
Hi guys
I have an Onkyo 705 receiver and I notice that the 'white noise' sound that is emitted during calibration setup appears inconsistent. Most notably, my left front RTi8 speaker sounds very different to the right speaker. The calibration levels are the same but the right speaker emits a much higher amount of treble within the 'white noise' sound.
Is this normal?
Daniel
Post edited by silversubaru on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2009
    Hi guys
    Is this normal?
    Daniel
    Hard to say.
    Have you tried swapping the speakers to see if the effect stays to the right or moves with the speaker?
    If it moves with the speaker - then it could be you have some sort of speaker problem.
    If it stays, then it could be other factors - such as room acoustics could effect how you 'hear' the sound.
    You could then try to switch the L & R speaker cables on the back of the AVR to try again and hear if the sound 'moves' with the cable changes.
    If it stays to the right - then I'd say something in your room acoustics is effecting what you are hearing.
    If it moves with the cable swap - could be something with your AVR.
    I'm of the old 'shotgun' school of troubleshooting....start with the easy big changes to shoot for to isolate the problem :D
  • mdk5068
    mdk5068 Posts: 204
    edited July 2009
    Is any of your equipment used? nvm tracy went above and beyond, lol
    Hi guys
    Is this normal?
    Daniel
    Bulls make money.
    Bears make money.
    Pigs get slaughtered.
    You, my friend, are the bacon.
  • silversubaru
    edited July 2009
    I had the equipment since new. Thanks for the practical suggestions, I will try them just now. The noise is definitely different and not due to room accoustics, the right RTi8 is very harsh in terms of the treble sound but let me fiddle a bit with the cables first!
  • silversubaru
    edited July 2009
    Quite strange....
    I swapped both the L+R plus the bi-amp L+R and still the right front has a much higher treble output in the white noise.
    I then took an RTi8 from the rear and into the right front position and still the same higher treble output in the white noise
    I then took the RTi8 from the rear and put it into the left front position and the result was the slightly more muffled white noise sound so it definitely is not the left front speaker that is the problem.
    I'm a bit stuck- any other suggestions?
    Daniel
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    Troubleshooting can be time consuming
    especially swapping to isolate
    because that will need to include isolating all components - speakers, cabling, wiring etc, amp, preamplifier
    it could be fun and frustrating
    but
    GOOD LUCK......
  • Erik Tracy
    edited July 2009
    Quite strange....
    Daniel
    If you have swapped the cables and the speakers and the 'problem' is still on the right side, then I'm back to thinking it is your room acoustics.
    What is on the 'right side'? A wall, pictures, a window - something that is adding reinforced 'reflections' of the sound to make it sound brighter?
    Just tossing out some ideas...
  • kuntasensei
    kuntasensei Posts: 3,263
    edited July 2009
    Is it just for calibration tones, or are you hearing excess treble during regular listening material? 'Cause your 705 has Audyssey MultEQ XT, which would help mitigate any acoustic issues your room has if you calibrate very carefully. For more info on proper setup, check the setup FAQ I wrote for the 705 over at AVS.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Erik Tracy
    edited July 2009
    Does the 705 let you go look at the results of its post calibration setting?
    That might be another way to determine what is going on.
    For example, for my Yamaha, instead of Audessey, it has YPAO for autocalibration, but after I make a run, I can go look at how the speaker levels were adjusted, and what the equalization was for frequency bands.
    I can see if the right front speaker was boosted or cut for volume levels vs the other speakers, and I can see what frequencies were boosted or cut compared to the other speakers as well.
    As you move speakers around and cables, maybe you should recalibrate each time you move something then look at the results. If the AVR is adjusting levels and frequencies that follow the changes, then you may have something 'bad' in your system.
    If the AVR is making the same changes only to the right side, then it is sensing and compensating for something in the room acoustics.
  • AudioGenics
    edited July 2009
    IF room acoustics
    then the electronics also would need to be swapped out
    to confirm that the issue is not being cause by a amplifier, preamplifier or even in the test calibration process.
    or take the complete system to a different room and see if the problem still follows....
  • silversubaru
    edited July 2009
    I think I have fixed it. I unplugged all the cabling, plugged everything back in and the high treble noise has gone away.
    Maybe just a glitch in the system??
  • kuntasensei
    edited July 2009
    You know what you could have had? One of your speaker cables near a power cable. I had that issue once, and rerouting my wires to get the power away from the speaker cables fixed things.
    Equipment list:
    Emotiva XPA-3 amp
  • kuntasensei
    edited July 2009
    Erik Tracy wrote: »
    No, the 705 doesn't let you look at the equalization, nor does any other receiver with Audyssey MultEQ XT (barring the pro version that will show you the correction curve on a PC, but you still can't tweak individual frequencies). The Yamahas use a very broad and basic EQ with pre-defined bands, so it's easy to display that on the screen. Audyssey can make hundreds of dynamic adjustments, so there's no way receivers could even represent the equalization on-screen. It basically reads hundreds of points along the frequency range then creates an inverse of what it hears in your room to give you flattened response.
    Equipment list:
    Emotiva XPA-3 amp
  • AudioGenics
    edited July 2009
    good deal... the old and tried process of elimination prevails.
    still should see if you can determine the real root cause...
    possibly a faulty cable or connection or 'gremlins'.
