naked wire vs plug vs banana plug
SivaNevets
sorry i mean pins and banana pins
whats the difference? i just bought belking pureAV 100ft 16 gauge speakerwire it came with 4 pairs of plugs. they sound wonderful and look beautiful compare to my old alluminum ones came with my old klipsch speaker.
i wonder what does these plugs do?
isnt plug naked wire into speaker and receiver enough? and why theres banana plugs? whats the difference? do they improve soundquality (i thought more plugs is worse)?
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Post edited by SivaNevets on
I use them to ensure a proper connection to my speaker/amp when hooking things up together. Also you don't have any wire sticking out to make any contact with the other end in case that were to ever happen (maybe you bump into something etc). Also imo its a much cleaner install.
One more thing, youre not related to Slowpolky right?Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
no man im fastpolkyFront: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
so am i suppose to use the pins for both end of the wires? (speaker and receiver)
i dont think these things will stick in to my receiverFront: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
IMO
there are various methods sold to provide mechanical connections
many were original designed for a specific application
ring and tip for example was developed for the telephone industry.
just keep to the fundamentals.
strong, clean, and easy to service connectors will be fine.
If you plan on connecting and disconnecting frequently then choose something
appropriate.
The banana plug (male) and banana jack (female) was
invented in 1924 by Richard Hirschmann
WHY is th banana jack the female ? Ironic ..... -
so should i use them? (one end or both end)
or should i buy more?Front: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
I think the pins would come in handy if you have the clip type binding post as they are very thin and small. Nanner plugs are thick and plug in to the binding post. Most people use them for convenience if they are plugging and unplugging their gear often. I use nanner plugs as I like the way they look and the ease of use when disconnecting my gear. I don't think there is a proven sonic improvement using them.
thx everybody. so if i understood correctly of what you saying, i dont really need them if they r the only speakers i have.Front: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
It's just a matter of convenience, theyre not required at all.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
It just makes better contact and allot easier to set up without **** the wires in. I got some of these and they're well worth the money took a little time to get here though.
http://cgi.ebay.com/24-PCS-Nakamichi-Speaker-banana-plug-connector-24k-Gold_W0QQitemZ320397952166QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4a9934c4a6&_trksid=p3911.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C293%3A1%7C294%3A50 -
SivaNevets is my brother
do they go both end or just the speaker end?
what is the proper way to plug the speaker wires to the receiver?Front: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
Nice plugs zarrdoss, I'm using bluejeans plugs. Heavy lil buggers given their size :cool:Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
SivaNevets wrote: »do they go both end or just the speaker end?
You can have them at both ends, I do. -
Thanks, after seeing a set of four in BB go for over $20 and they sucked. These are real good quality and don't come off, and less than $17 for 24, and I just ordered 24 more for the hell of it. -
I might just order some as well, my HT speakers are plugged straight in via wire. Only using plugs for my SDA's, tho it might be a bit tricky plugging all pins/plugs in the back of my Denon, think I'll just do it on the speakers end in case I just want to perform a quick swap while leaving cables in place.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
any recommendations from monoprice? im buying all the cables from them very shortly.Front: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
I didn't see anything there Id take over the ones I got on E-bay. But if I had to I would go with these.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2 -
Exactly the ones I was looking at @monoprice. Go with those if youre going to buy only fromt hat siteTruck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
didnt notice the ones u mentioned from ebay has FREE shipping to canada.
Thanks Ill grab a bag of banana from ebay.Front: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU -
SivaNevets wrote: »didnt notice the ones u mentioned from ebay has FREE shipping to canada.
They take a while because they're coming from Hong Kong but worth the wait, let me know what you think. -
I like to just use good cables, I feel you get better contact with bare wire.
whatever works for you, I think it makes good contact either way, I just hate messing with the manual hook-up.
I use the closed screw type from monoprice on 14ga. wire with no problems. They sure make life easy
wow it's cheap. thanks for the link -
How long of a wait on the Nakamichi plugs?Mike
Pioneer SC-05 Receiver
Polk SDA-2b
Polk RTA 11TL w/RDO-198's
Polk RT25i Satelite Speakers
Polk CS 400 Center Speaker
Polk PSW 350 Sub Woofer
Samsung 46" 1080p LCD TV -
This last batch took 12 days from order to door.
