Yamaha M-35 troubles
nguyendot
nguyendot Posts: 3,594
edited July 2009 in Electronics
So I have a pair of M-35 stereo amps that I love. They're low powered and I plan on using them to bi-amp a pair of speakers someday. The problem is one of them has no/scratchy output on the left channel. It cuts in and out by itself and sounds scratchy when it happens.
I really want to have it repaired. What should i look for inside if I can maybe fix it myself? If not, where can I take it that wont cost an arm and a leg?
Main Surround -
Post edited by nguyendot on
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    just checking to see if your did the channel swap L-R and R-L
    to confirm it is the amp and not in the speakers or source.
  • Systems
    Systems Posts: 14,872
    edited July 2009
    The cutting in and out might indicate a wonky relay.
    Testing
    Testing
    Testing
  • nguyendot
    edited July 2009
    I did swap, it is definitely the amp. If i switch it into 4 channel mode, only the pair on that side work as well.
    What can I do about a wonky relay?
    Main Surround -
  • Systems
    edited July 2009
    nguyendot wrote: »
    Keep in mind that is only one possibility,it could be somthing else entirely.If it is the relay it would need to be replaced, but you could try resoldering the pins to the PC board as it might be just a cold solder joint.
    Testing
    Testing
    Testing
  • nguyendot
    edited July 2009
    I will definitely look into that. I may look at the solder points on this amp and see if i can fix it. Can a bad or rusty pot cause this too? It has 2 volume controls and if i mess with that channels volume controls I can sometimes get it to come back, but only at full volume.
    Main Surround -
  • Systems
    edited July 2009
    nguyendot wrote: »
    Yes if thats the case then I would take a closer look at that pot.Try bypassing it and see what happens.
    Testing
    Testing
    Testing
  • nguyendot
    edited July 2009
    excuse my ignorance, how do i do that?
    Main Surround -
  • Systems
    edited July 2009
    nguyendot wrote: »
    Desolder the signal input and output pins of the pot or (remove entirely) and replace with a wire jumper.If you can post a pic of the pot and how it is mounted I might be able to give you further guidance.
    Testing
    Testing
    Testing
  • nguyendot
    edited July 2009
    Will do when I get time this weekend. Headed out of town right after work today. But I definitely want to get this fixed. I love having a matched pair of amps.
    I understand exactly how this troubleshooting (logically) works, but not how to go about it.
    Let you know as soon as i can.
    Main Surround -
  • shadowofnight
    shadowofnight Posts: 2,735
    edited July 2009
    nguyendot wrote: »
    It's the volume control pot....same exact problem with the one I had . Since the amp only had spring type speaker connections in the rear, I gave it away to a friend.....he fixed it by replacing the pot.
    The first rule of Fight Club is you don't talk about Fight Club
  • AudioGenics
    edited July 2009
    just another thought
    did you try the special spray cleaning and lubricating the volume pot
    I forgot what another post suggest DeTox Gold
    I'll search for the name.
  • AudioGenics
    edited July 2009
    plain DeOxit and DeOxit Gold.
    The first cleans the second conditions the contacts.
  • nguyendot
    edited July 2009
    Where can I get it from?
    Also, why is his power LED blue/white? I'd love to change mine to that color.
    Also, if I were ambitious, could i change out the speaker connectors for 5 ways?
    Main Surround -
  • AudioGenics
    edited July 2009
    I have not used this product but similiar cleaner/lubricant product
    here is the url that I found regarding DeOxit $9.99
    http://www.radioshack.com/product/index.jsp?productId=2104746
  • AudioGenics
    edited July 2009
    appears to be out of stock online
    check local stores...
  • nguyendot
    edited July 2009
    THanks, will try that when i get home saturday
    Main Surround -
  • nguyendot
    edited July 2009
    I tried deoxit and it did nothing, the channel is still dead. It doesn't even scratch anymore, it just doesnt have any output whatsoever. I have no idea what to do, i'm not that into the circuits and stuff.
    Main Surround -
